which cluch cabel setup ?
Old 07-18-2007, 03:47 PM
66belair
66belair's Avatar
Default which cluch cabel setup ?
hi i see that most recomend going to an aftermart clutch cablesetup--is there any better than the others , or are all name brands about the same -- also for street use , should i just use cable and quadrant or should i add the firewall adjuster also -- going on my daughters 5.0/t-5 87 conv with stock motor .. thinking of steeda ..thanks bob
66belair is offline
Old 07-18-2007, 03:57 PM
86 5.0L
86 5.0L's Avatar
Default RE: which cluch cabel setup ?
any quadrent and firewall adjuster is fine steeda is the most common and best, your OEM cable is the most durable also so stick with that
86 5.0L is offline
Old 07-18-2007, 04:22 PM
shibby_cbs
shibby_cbs's Avatar
im an idiot so im gonna ask what are the benefits fo a firewall adjuster and what exactly does it do?
shibby_cbs is offline
Old 07-18-2007, 05:12 PM
Maxwelhse
Maxwelhse's Avatar
The stock adjustment system uses two plastic paws (one is the quadrant) under the dash to adjust the tension on the cable as the clutch wears. The problem is that the system, in my opinion, never worked very well to begin with and as time goes on it gets worse. The little teeth on the paws wear down and sooner or later they no longer engage each other at all.
If you choose not to run a firewall adjuster with an aftermarket quadrant, you'll have to get an adjustable cable and adjust it under the car periodicly. My OE replacement grade aftermarket cable was adjustable, so its not a big deal to find one, it's just a pain in the butt. Plus... With a firewall adjuster its easier to fine tune your clutch feel to suit your needs.
All that being said, my adjuster and quadrant are both steeda and I'm happy with them.
Maxwelhse is offline
Old 07-18-2007, 06:57 PM
lookin4astang
lookin4astang's Avatar
I'll second running a stock cable. I have an adjustable cable on my fox right now. Worthless. It wore down so I'm having to readjust it about once a week. Not to mention it just feels weaker. If I were you, I'd buy a firewall adjuster, an aftermarket quadrant (that ISN'T) plastic, and a STOCK cable. You'll be much happier.
lookin4astang is offline
Old 07-18-2007, 07:01 PM
945LSTANG
945LSTANG's Avatar
i have the steeda kitand love it. cheap, good quality part.
945LSTANG is offline
Old 07-19-2007, 09:42 AM
66belair
66belair's Avatar
on the ford cable---is it a stock replacement //ford racing //adjustable or not
do you have a part number and would in be better than steeda's one
66belair is offline
Old 07-19-2007, 11:13 AM
86 5.0L
86 5.0L's Avatar
have you read the posts belair? the OEM ford cable is better, the firewall adjuster is all you need to adjust the cable
86 5.0L is offline
jwog666
12-27-2021 08:09 PM
fastbackford351
10-01-2015 12:24 PM
guitarman376
09-30-2015 05:54 PM
Drastang
09-29-2015 03:31 PM
Quick Reply: which cluch cabel setup ?
