I got this code from my computer DTC222
Old 07-25-2007, 06:18 AM
Stanpower
Stanpower's Avatar
Default I got this code from my computer DTC222
Can anybody here explain what that code means?.................
Stanpower is offline
Old 07-25-2007, 07:47 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: I got this code from my computer DTC222
LOSS OF IGNITION diagnostic monitor signal right side =222
mjr46 is offline
Old 07-25-2007, 08:37 AM
Joel5.0
Joel5.0's Avatar
Suggest to confirm that is the code you're getting.....222 is not a TFI ignition valid code, it's an EDIS ignition type code......
Joel5.0 is offline
Old 07-25-2007, 09:47 AM
mjr46
mjr46's Avatar
222 is a valid tfi ignition module code for 94-95 mustangsyou have to have access to factory troubleshooting on this as I do. a quick glance at the troubleshooting chart and it leads you to a test of the ICM (Ignition control module) but as joel 5.0 stated I'd verify your code first. If you just like to slap parts put on a new tfi module as it's the brain of the ignition system that interperts all signals or you can take the module off and have it tested or test it your self with an ohmmeter. are you having start /stall problems with the car or will it not start????
mjr46 is offline
Old 07-25-2007, 01:51 PM
Joel5.0
Joel5.0's Avatar
222 is NOT valid for TFI.....for EDIS systems....yup......as defined by Ford..... = Loss of IDM signal right side (dual plug EI).......or the 2.3L 4-cyl. engine with 8 spark plugs.......TFI's don't use an IDM LH side signal + IDM RH signal.......check your nomenclature...
Joel5.0 is offline
Old 07-25-2007, 03:31 PM
Stanpower
Stanpower's Avatar
ORIGINAL: mjr46
No the car works fine with no problems, every once in a while the check engine like will come on. So I checked my stang computer and this is what code it had in there..?weird anybody else every have this one come up?
Old 07-25-2007, 07:58 PM
Joel5.0
Joel5.0's Avatar
ORIGINAL: Stanpower
ORIGINAL: mjr46
I wonder why............
Joel5.0 is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: I got this code from my computer DTC222
