4bbl
Old 08-05-2007, 01:17 PM
highskewlmustnglvr86
highskewlmustnglvr86's Avatar
Default 4bbl
hello everyone i recently put a 5.0 in my mustang and noticed that my 4bbl isnt kicking in...when hit the throttle under the hood with the car off i can see fuel shooting into the front but not the back barrels...whats wrong with this? its a brand new holley 600 #1850...thanks
tyler
highskewlmustnglvr86 is offline
Old 08-05-2007, 01:40 PM
BlessedHellride
BlessedHellride's Avatar
Default RE: 4bbl
Try it with the engine running. You will be amazed at what you find!!!
BlessedHellride is offline
Old 08-05-2007, 01:56 PM
turboblast
turboblast's Avatar
Default RE: 4bbl
1850 is a vacuum secondary carb i believe, the secondaries will only open when its running. If they feel like there not coming open ,when driving it, you can change the spring that controls the secondaries. Go to holleys website for instructions on tuning the carb, there is lots of good info there.
turboblast is offline
Old 08-05-2007, 03:15 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: 4bbl
well that's also because it's not a double pumper meaning there is only an accelerator pump on the primary circuit and unless there is a vaccum drop the secondaries will not open because it's a vaccum secondary carb. If I were you I'd study a little bit or google the theroy and operation of the different types of carbs......cause you have vacccum secondary carbs, weighted secondary carbs, mechanical secondary carbs, single accelerator pump carbs, double pumpers ect ect......... if you have a problem ...what is it and what are you trying to solve????? have you taken the car out on the road to see if the secondaries kick in??
mjr46 is offline
Old 08-05-2007, 10:14 PM
Default RE: 4bbl
well i acutally just rebuilt the engine and put new rod bearings and stuff in it so i wanted to break it in b4 i get on it hard....i thought it might be because it is a vacuum carb but i just wasnt sure...thanks everyone...o yea and does anyone know where i should set the mixture at? i have an edelbrock torker intake stock heads with the exhaust bumps removed longtube headers and an off road x pipe...thanks
tyler
uberstang1
09-20-2015 06:42 PM
ding56
08-14-2015 02:40 AM
Volcom66
08-11-2005 07:51 PM
70 Mach
04-19-2005 04:52 AM
kevs66coupe
02-19-2004 04:09 PM
Quick Reply: 4bbl
