keeps catching fire
Old 08-07-2007, 10:59 PM
86onboost
86onboost's Avatar
Default keeps catching fire
Ok i we finished puttin in the 302 in my fathers mustang, and once we start to crank it, it soundslike its going to crank and then bam,the carbruetor catche on fire.... I dont have an aircleaner or any paper element on it... it catches fire towards the inside-middle of the carb....
when the engine was out of the car... we took the number 1 cylinder
and put it at TDC and then put in the distributor..... 0
so idk if the timming messed up or what.... do you think its has to much fuel, or too less???
86onboost is offline
Old 08-07-2007, 11:06 PM
mattdel
mattdel's Avatar
Default RE: keeps catching fire
timing is off. you are firing spark with the intake valve open.
mattdel is offline
Old 08-07-2007, 11:09 PM
Blckstng93
Blckstng93's Avatar
Does it go boom to like its backfiring? Im guessin too much timing.
Blckstng93 is offline
Old 08-07-2007, 11:13 PM
67mustang302
67mustang302's Avatar
Was the piston at TDC compression or exhaust? Your timing may be out 180deg
67mustang302 is offline
mattdel
mattdel's Avatar
ORIGINAL: 67mustang302
yup
mattdel is offline
Old 08-07-2007, 11:17 PM
86onboost
86onboost's Avatar
thats wat is probably is... 180 degrees, off..
so how do i go about fixing this.....
should i take the dizzy out, then turn the crank another 180 degrees, then put t he distributor back in??
Old 08-07-2007, 11:22 PM
mattdel
mattdel's Avatar
just lift the distributor a bit, turn the rotor exactly 180 around, and stick it back in.
obviously, you should know that it turns even more when you mesh the gear with the cam. make the appropriate adjustments for that, and you'll be all set.
mattdel is offline
JDWalton
09-24-2015 08:47 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: keeps catching fire
