non ford auto problem help me if you can
Old 08-08-2007, 05:02 PM
mattdel
mattdel's Avatar
Default RE: non ford auto problem help me if you can
is each coil pack seperate? so you can replace 1 by 1? i cant remember...
but if that's the case, buy a code reader from autozone. $30-40. read your own codes.
if its a solid light now, it will probably be a misfire code.
read it, clear it.
move the coil pack from that cylinder to another one, switch 'em out.
fire it up.
when/if the code comes back, read it.
if the misfire moved with the coil, well there ya go.
mattdel is offline
Old 08-08-2007, 05:09 PM
junknotch
junknotch's Avatar
great idea and each coil pack is seperate thanks for your help. I posted this on a chevy site and got not one answer. My fiance does not like my notch and says guys that drive fox body stangs are dorks. She is a camaro fan, Well I said this long time ago guys that drive stangs are normal everyday guys, guys that drive camaros are your preppy little b***hs. Ford guys all along are a better group. Thanks again !!
junknotch is offline
Old 08-08-2007, 05:14 PM
PJB
PJB's Avatar
Try www.w-body.com for tech help.
I know that when the intake gaskets and/or plenum go bad on these motors the car misfires and is often hard to diagnose.
It happened to my father's '97 Cutlass Supreme. He took it to 3 different shops and the last one was able to fix it right by replacing the intake gasket.
PJB is offline
Old 08-08-2007, 05:34 PM
VigCS
VigCS's Avatar
ORIGINAL: P Zero
Im not sure if this applies to the 3.4 but I know for a fact that some 3.1 engines with the plastic intakes are prone to cracking. Theyve gotten so bad MOST auto parts stores STOCK the intake kit. You might want to call the dealer and see if this applies to your car. If it does then it would be a TSB or warranty issue which would more than likely mean free service and parts.
-P.
Those are the Series II 3800s.
VigCS is offline
Cannibal_carnies
03-02-2023 06:17 PM
ShaneB26154
35
03-04-2021 04:05 AM
Jskeezy84
09-08-2015 01:40 AM
Stilz
08-18-2015 09:40 AM
Quick Reply: non ford auto problem help me if you can
