Soft pedal with brakes
Old 08-11-2007, 10:11 PM
tmajikman
tmajikman's Avatar
Default Soft pedal with brakes
What else can make the brake pedal get soft and go to the floor other than air in the sytem. Can a bad booster or m/c do it as well. I had a bad wheel cylinder that I replaced and bled the complete system. Looking for ideas on what to look into. Thanks
tmajikman is offline
Old 08-11-2007, 10:14 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: Soft pedal with brakes
Either a leak or a bad m/c.
PRO50SC is offline
Old 08-11-2007, 10:16 PM
tmajikman
tmajikman's Avatar
Thanks pro, low rear shoes would not do it, would they.
Old 08-11-2007, 10:17 PM
AdderMk2
Banned
AdderMk2's Avatar
swelling rubber brake line..
always fun when those pop, out on the road.
AdderMk2 is offline
Old 08-11-2007, 10:19 PM
94IVGT
94IVGT's Avatar
yes worn rear brake shoes whould cause the pedal to go to the floor. as would a M/C if the seals on the piston are worn out, the fluid can seep by the seals.
94IVGT is offline
tmajikman
tmajikman's Avatar
This is not my car, I will look at the hoses as well. Are the stainless steel flexible hoses really worth the extra cost on our cars for the front brakes. I want to find out which way to go before I change out my hoses.
Old 08-12-2007, 10:26 AM
creekrat
creekrat's Avatar
How were the brakes before you replaced the cyl? Was the cyl just damp or was it causing the pedal to drop with a real bad leak? The reason I'm asking is that if the pedal did not go to the floor and feel mushy before you replaced the cyl, it stands to reason that there must still be air in the system somewhere. If the pedal was soft before, then it is possible it is the master, asuming there is no other leaks.
creekrat is offline
Thunderball
15
11-22-2015 11:49 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Soft pedal with brakes
