bout to intall rockers on stock heads?
Old 09-01-2007, 12:23 AM
blk89lx
blk89lx's Avatar
Default bout to intall rockers on stock heads?
ok well im about to install some 1:6 rockers on my stock heads just curious how the right way they should be put on is ? can i just bolt them down or is there more to it? anything i can tell me would help
blk89lx is offline
Old 09-01-2007, 12:31 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: bout to intall rockers on stock heads?
if they are pedastal mount what I do is run each cylinder up to top dead center and then run the bolt down untill you reach0 lash = slight drag on the push rod while spinning and then you should only have enough left after that to turn it 3/4 to 1 full turn to reach about 25 ftlbs of torque on bolt if it takes more than that you'll have to shim up the pedastals with a shim kit
mjr46 is offline
Old 09-01-2007, 12:34 AM
mjr46
mjr46's Avatar
by running each cylinder up to top dead center you can do both exhaust and intake rocker at the same time and then just follow the firing order from there to the next cylinder...I usually shine a small led light while having someone spin the motor over to see when each cylinder is at TDC and reference it to the dizzy rotor in relation to the plug wire location on the cap
mjr46 is offline
Old 09-01-2007, 09:22 AM
SoDakStang
SoDakStang's Avatar
Should also have directions with the rockers.
SoDakStang is offline
Old 09-01-2007, 09:40 AM
5.0stanger
5.0stanger's Avatar
ORIGINAL: SoDakStang
I am guessing he did get any and that is why he is asking...
http://www.fordracingparts.com/downl...M-6564-All.pdf
Take a look there, you have bolt on rockers
5.0stanger is offline
copestang
10-11-2015 07:17 AM
uedlose
09-30-2015 08:01 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: bout to intall rockers on stock heads?
