Hows this combo sound
Old 09-06-2007, 12:16 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: Hows this combo sound
ORIGINAL: Mustangkiler
Hey adder i didnt know you changed your name too xpballer
lol.. I have posted that combo a few times... it was what I had planned for my 302
AdderMk2 is offline
Old 09-06-2007, 09:30 AM
XPBaller
XPBaller's Avatar
Well i hope to be blown in the future sothe camwill help out, and, besides i have a 94 so the LS will be good to me...
Adder, you posted that same combo? I thought you just used those heads, i didnt knowyou planned on the same cam and manifold? Why did you change it up?
XPBaller is offline
Old 09-06-2007, 09:32 AM
AdderMk2
Banned
AdderMk2's Avatar
I went with a bigger engine... and my aspiration plans changed
AdderMk2 is offline
Old 09-06-2007, 01:41 PM
XPBaller
XPBaller's Avatar
So you guys think this will perform well on my stock 302 and have room to perform on a blown 347?
XPBaller is offline
Old 09-06-2007, 09:53 PM
5.0liter_rice_eater
5.0liter_rice_eater's Avatar
I don't mean to hack this thread, but I have aquestions about these steeda cams. I know the ford racing cams are a little out dated, but how would the B cam stack up against the steeda #18? The both have the same amount of lift (.480 w/ 1.6 and .510 i believe with 1.7)and lobe seperation (112*), but the B Cam has a duration of 224* 0.050 intake and exhaust in contrast to steeda's 220* on the intake and 226* on the exhaust. I understandwhat this means, but a little unclear on how this will effect the performance or which cam willperform "better."
5.0liter_rice_eater is offline
Old 09-06-2007, 10:38 PM
AdderMk2
Banned
AdderMk2's Avatar
since both the intake and exhaust durations are the same on the letter cams... you will never get the best efficentcy(sp) from them. your intake valve is larger than your exhaust valve. So leaving the two open for the same amount of time makes no sence.
The steeda on the other hand has a longer exhaust duration, which will clear the cylinder better, causing more of a scavenging effect once the intake side opens up again,
You will probably see better numbers with a steeda cam over a B cam
AdderMk2 is offline
Old 09-06-2007, 11:14 PM
kev2369
kev2369's Avatar
ORIGINAL: XPBaller
I didn't know that you were running a 94.... Yeah that cam will be good on a 94 naturally aspirated car... It will help with idle...
kev2369 is offline
Old 09-07-2007, 02:58 AM
5.0liter_rice_eater
ORIGINAL: AdderMk2
Right on, that makes sense. Thanks.
Old 09-08-2007, 12:33 PM
Curlytop
Curlytop's Avatar
i have the steeda #19 cam. love it! the only thing i think can be better is a custom grind. which you can still get that 114* or 115* lsa to help work with your computer and vaccum. plus get the bigger lift if desired for your application.
Curlytop is offline
musnicki
09-23-2015 07:11 AM
mustangchef
09-04-2015 08:08 PM
raleigh05GTO
09-04-2015 07:09 AM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Hows this combo sound
