Piston Clearance
Old 09-21-2007, 09:33 PM
hillbilly pony
hillbilly pony's Avatar
Default Piston Clearance
Ok heres the deal. Will Speed Pro Flat top forged pistons P/N TRW-L2482F30 clear 2.02 valves. I have a set of windsor sr heads and i know some people who have ran 1.94 holley heads (systemaxkit)with 1.7 rockers with no problems phase two of my need is if the vlve does clear circumfrence does anyone know approx what lift those will clear with stock stroke. The chambers are still 64cc as far as i know.
Thanks for the help.
hillbilly pony is offline
Old 09-21-2007, 10:24 PM
my77stang
my77stang's Avatar
Default RE: Piston Clearance
yes, pretty much any forged aftermarket piston will work with 2.02's providing you dont have some super radical crazy *** cam
my77stang is offline
Old 09-21-2007, 11:00 PM
AdderMk2
Banned
AdderMk2's Avatar
lift does not determine PTV clearance issues...
duration, and cam event timing are what cause it
AdderMk2 is offline
92civy
92civy's Avatar
^^ pretty much. just dont have a huge camand you'll be ok.
92civy is offline
Old 09-22-2007, 12:32 AM
dimebag
dimebag's Avatar
wont be 100% sure untill you clay it anyway....
dimebag is offline
Old 09-22-2007, 07:37 PM
tinman
tinman's Avatar
+1
Just do the clay check thing and rest easy.
As long as cam is under 260 or so @.050 I think you'll be fine.
Look for about .100 minimum clearance on both valves.
I know that there have been engines built with as little .040 on both valves but thats NOT the way to do it right.......
tinman is offline
Old 09-22-2007, 10:02 PM
67mustang302
67mustang302's Avatar
Deck clearance and head gasket compressed thickness will play into it as well
67mustang302 is offline
Tivo304
08-28-2023 12:19 PM
uberstang1
12-07-2017 07:10 AM
poke68
12-15-2015 06:25 PM
degner122
09-16-2015 07:09 AM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: Piston Clearance
