Fmu = Temporary Solution?
Old 12-11-2007, 01:18 AM
LCBlackDep183
LCBlackDep183's Avatar
Default Fmu = Temporary Solution?
Its getting close to that time, ill be doing my p600b install in less than a month. Now that its getting closer and closer, im realizing I dont quite have it in my budget right now to go with the injecters, New maf, and a complete tune. Would using the fmu with my 19s for now be a solution i could use for a few months till im ready to do the full tune?
LCBlackDep183 is offline
Old 12-11-2007, 02:25 AM
ampman_27
ampman_27's Avatar
Default RE: Fmu = Temporary Solution?
on my old mustang i used a 5psipressure switch on the charge pipe that opend a cold start injector on the intake pipe on my turbo, it was a very crude setup and not very good for the turbine but worked for 9 months with no problems.
ampman_27 is offline
Old 12-11-2007, 06:53 AM
richs347
richs347's Avatar
There's nothing wrong with using the FMU. They ran superchargers for years with this setup before being able totune with larger injectors. It's a little more crude but it works. As your budget allows, buy the larger injectors and supported pieces and get a good tune. The instructions that come with the superchargers are usually written around the use of the FMU.
richs347 is offline
Old 12-11-2007, 09:17 AM
LCBlackDep183
Yeah thats what i was figuring. I already have the injectors and a drawthrough maf, but i want to swich to a blowthrough setup and then i need to get the tune done, just wont be in my money range for a few months.
Old 12-11-2007, 10:03 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
I ran one on mine for the first three years. It worked, "ok" but the set up I run now is much much better. What boost are you gonna be running?
PRO50SC is offline
Old 12-11-2007, 10:11 AM
bighungrymatt
bighungrymatt's Avatar
I run one on mine right now also...
bighungrymatt is offline
Old 12-11-2007, 08:14 PM
LCBlackDep183
Im running a 12lb pulley pro, I doubt ill get all of that because of my e7s :P.
Old 12-11-2007, 08:27 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: LCBlackDep183
Hmmmm, good luck w/ that. You may get lucky. Mine never ran that well w/ the stock 19's and the fmu. What do you have for ignition system?
PRO50SC is offline
Old 12-12-2007, 11:16 AM
LCBlackDep183
I have a accell 300+ ignition right now, what problems did you have with the fmu? just lagging?
Old 12-13-2007, 02:38 AM
LCBlackDep183
I also need a new filter for my charger, anyone know of a site i can get a replacment for it that wont be as expensive as procharger direct?
Urambo Tauro
Oil and Oil Related Topics
12-11-2017 07:16 AM
mirandaandjimmy
11-16-2015 08:51 AM
fastbackford351
10-01-2015 12:24 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Fmu = Temporary Solution?
