harmonic balancer Q
harmonic balancer Q
hey guys im gonna get my rotating assembly balanced and i wondering if i should get a new harmonic balancer or use the old one?
if a new one what kind/brand would be best from your experience?
thanks for the feedback
RE: harmonic balancer Q
Just remember that the balancer is key to engine longevity, going cheap could result in poor damping capabilities, safe yourself the trouble and by a nice one, ATI is top of the line, there are some others for a little cheaper, anything from 150 up should be a good buy depending on your setup and what you want out of it.
professional products and ATI both have good stuff. Fordstrokers.com has balancers.
heres the thing, u might need a spacer, all depends on car and balancer size. i needed a .95 spacer for my guess what, my sn95 lol.
aode-164tooth 11.5in circle
stroker motor 28oz imbalance, or internal 0 balance.
0 balance ftw, and with a professional products balancer you can remove the weight for a 0 balance or change the weight between 28 and 50 oz depending on your application. the only thing i DONT like is that the timing marks are printed not stamped. I made a small notch @ zero with a file on mine and when the numbers wore off (from me cleaning while the motor was apart) i used a piece of MSD timing tape based off the notch i put in it.
jessicarabbit
09-25-2015 12:41 PM
LivingInThePast
09-16-2015 12:20 PM
09-08-2015 11:50 AM
Urambo Tauro
08-27-2015 10:53 AM
