Very low oil pressure
Old 01-23-2008, 01:49 PM
Darin M.
Darin M.'s Avatar
Default Very low oil pressure
I recently bought a '91 LX 5.0 with 94,000 miles. The car is totally stock and runs great (besides being slow).
I noticed that the oil pressure is low when I first start it and very low (almost in the red) when hot. It has had regular maintainence since at least 2001. The oil in it now is 10-40.
I've had a few 5.0s and this one is the only one that worries me with the oil pressure. What could it be? Should I go with a 20-50 oil or try something else?
Thanks,
Darin
Darin M. is offline
Old 01-23-2008, 01:58 PM
WhiteWindsor
WhiteWindsor's Avatar
Default RE: Very low oil pressure
A thicker oil might put a band aid on it but wont solve the problem. I would do a compression check and get another gauge, they are notorious for not reading correctly. Do a compression check and see what you have. Are you burning or losing oil anywhere?
WhiteWindsor is offline
Old 01-23-2008, 02:00 PM
WhiteWindsor
ORIGINAL: FASTBLACK
forgot to add, it could be internal. But at least withthese simple steps you can rule them out.
Old 01-23-2008, 04:06 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
The first thing I would do is screw in a mechanical gauge and check it. It might just be a faulty sending unit. Look at the simple things first.
PRO50SC is offline
Old 01-24-2008, 12:10 AM
Darin M.
Darin M.'s Avatar
No smoke, no drips, clean oil and coolant. It's actually very smooth. I'm hoping it's the sending unit like Pro50 said.
Darin M. is offline
Old 01-24-2008, 12:21 AM
VaRust
VaRust's Avatar
Thats what was wrong with mine.
VaRust is offline
Old 01-24-2008, 07:14 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: PRO50SC
exactly^^^^^^^^^...no need for compression checks until you can verify the functionality of the gauge and or sending unit..first things first.....like pro says if the mechan reading confirms a low pressure issue too..then it's internal but if not...it's a sending unit or gauge issue..most likely a sending unit
mjr46 is offline
jwog666
12-27-2021 08:09 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
wraith777
09-28-2015 10:49 AM
ccdguy
09-19-2015 05:20 PM
Quick Reply: Very low oil pressure
