would i have to flycut?
Old 02-09-2008, 08:36 PM
stamper5.0
stamper5.0's Avatar
Default RE: would i have to flycut?
i mean they split* because is a nitrous cam
stamper5.0 is offline
Old 02-09-2008, 09:01 PM
stamper5.0
stamper5.0's Avatar
also i have bbk shorty equal lenght headers now...should i get some long tubes?...or keep the shortys?
Old 02-09-2008, 09:06 PM
92GreyGT
92GreyGT's Avatar
Lift isn't really what gets you in trouble on piston to valve clearance, it's valve timing. The Comp nitrous cam is a very aggresive cam compared to the Comp cam. The Comp is going to have more overlap to help with scavenging (I think I spelled that wrong). The intake valve normally chases the piston but while the exhaust valve is open and the piston is on the way to TDC the intake valve cracks open and the rushing air going out the exhaust valve helps to start pulling the incoming air fuel mixture in. That is where the contact between the piston and valve happens.
92GreyGT is offline
Old 02-09-2008, 09:07 PM
92GreyGT
92GreyGT's Avatar
I'm a long tube man myself but what you have works good. It all depends on if you want to spend the money.
92GreyGT is offline
Old 02-09-2008, 09:08 PM
Joel5.0
Joel5.0's Avatar
B-303 overlap events @.050" tappet lift during overlap:
Intake open = 5° BTDC ---- Exhaust Close = 5° BTDC
NX274HR-14 overlap events @.050" tappet lift during overlap:
Intake open = 2° BTDC ---- Exhaust Close = 0° BTDC or TDC
Piston and exhaust valve will be "closer" to each other with the NX cam...... it needs to be clayed as 92GreyGT mentioned..... just to be $afe.
Joel5.0 is offline
Old 02-09-2008, 09:09 PM
stamper5.0
stamper5.0's Avatar
what long tubes would u reccomend?...income taxesso i have a little bit of money
Old 02-09-2008, 09:17 PM
92GreyGT
92GreyGT's Avatar
BBKs or Hooker headers, 1 5/8" is plenty big.
92GreyGT is offline
Old 02-09-2008, 09:20 PM
stamper5.0
stamper5.0's Avatar
alright...thanks alot for the help
Old 02-09-2008, 09:23 PM
92GreyGT
92GreyGT's Avatar
Good luck, let us know how that thing sounds with that nitrous cam. They are supposed to sound lumpy as hell compared to a N/A cam close to the same size.
92GreyGT is offline
Old 02-09-2008, 10:19 PM
stamper5.0
stamper5.0's Avatar
ya i will...i should be starting this week....maybe i can post a video of it...if i find out how too lol
Mustang_NTriangle
03-20-2009 01:37 PM
92civy
08-02-2007 09:36 PM
chrisal
07-12-2007 10:40 AM
LX 90
10-21-2006 02:23 AM
Milky
04-04-2004 03:24 PM
Quick Reply: would i have to flycut?
