Fog Light Fix - Easy As Pie
Old 02-16-2008, 04:08 PM
-SHIFTY-
-SHIFTY-'s Avatar
Default Fog Light Fix - Easy As Pie
Hey guys, just did this fog light fix thought I'd post my feedback and results for you all. This was a really simple wireing job. Just letting you all know you can find everything for this except the relay at your parts store and be rockin those fog lights how they were ment to in no time. I also chose a different power source instead of running a power wire throught the firewall and to the battery. I installed an in-line fuse under the dash, and power right into my fuse block. Anyone have any questions fire away, here are some pics of the final results. I don't have the lights mounted yet, but you get the idea.
Instructions:
http://www.corral.net/tech/maintenance/foglights.html
-SHIFTY- is offline
Old 02-16-2008, 04:13 PM
Streetracer911
Streetracer911's Avatar
Default RE: Fog Light Fix - Easy As Pie
What was the point of doing this? My fog lights work fine[&:]
Streetracer911 is offline
Old 02-16-2008, 04:50 PM
-SHIFTY-
-SHIFTY-'s Avatar
I guess the stock setup for fog lights is only to be used when the headlights are on. Its a wireing bypass to turn them on whenever. Read the link[:@]
-SHIFTY- is offline
Old 02-16-2008, 04:53 PM
Cobra77
Cobra77's Avatar
Also helps with the overheating/flickering problem a lot of Foxes have.
Cobra77 is offline
Old 02-16-2008, 06:53 PM
FuzzyDiceRule
FuzzyDiceRule's Avatar
lucky you, my foglights just dont work
i plugged em in before i put em in, worked fine, finished up, no dice, fuse is fine
i figure ill just make some brake cooling ducts out of the holes, theyre useless now anyway
FuzzyDiceRule is offline
Old 02-16-2008, 09:11 PM
bbbngowc
bbbngowc's Avatar
Was there a guide that you followed to do this? I was surprised to see that the fog lights don't come on unless the headlights are on. I would like to do the same to mine ... I was going to run a separate switch directly to them ...
bbbngowc is offline
Old 02-16-2008, 10:20 PM
bighungrymatt
bighungrymatt's Avatar
a lot of the foxes fog lights dont work... including mine
good find
bighungrymatt is offline
Old 02-16-2008, 11:13 PM
-SHIFTY-
-SHIFTY-'s Avatar
ORIGINAL: Cobra77
This is true and probably why some of you guys lights don't work now. I'm telling you take 2 -2.5hours a the most and fix your problem. Thislil mod is SO easy and you stillkeep the factory FL switch. Now I can use them whenever I want not whenever ford want me to. This is a must for all 5.0's around my parts. Good luck I have faithin ya.
-SHIFTY- is offline
Old 02-17-2008, 09:51 AM
HACKGT350
HACKGT350's Avatar
pie isnt easy but it does taste very good. as for fog lights ha mine already turn on with just the parking lights on and still stay on with the high beams on so ha to that...thats why 4 eyes are better[8D]
HACKGT350 is offline
Old 02-17-2008, 02:26 PM
aode08
aode08's Avatar
Ive heard of quite a few fires from the Fog Lights on the stock switch.
I suggest run them on its own stand alone fuse circuit and switch.
Dont go above stock wattage either on the bulbs
aode08 is offline
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
zanemoseley
09-06-2015 12:58 PM
zachary1988
09-04-2015 03:04 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Fog Light Fix - Easy As Pie
