306/w holley kit
Old 02-21-2008, 10:19 AM
92sleeper
92sleeper's Avatar
Default 306/w holley kit
Whats up guys im having my motor put together now and was wondering if anyone could tell me if this will be a good set up.Its a 306 w/keith black pistons stock crank a pretty simple short block and i have the holley systemax kit.I wasnt sure if i should stick with the holley cam it came with or go with something else does anyone have a similar setup and if so what kind of numbers are you pulling.
92sleeper is offline
Old 02-21-2008, 10:21 AM
w8less
w8less's Avatar
Default RE: 306/w holley kit
check out this guy and find more post by him
https://mustangforums.com/showProfile.asp?memid=42735
sounds exactky like his set up. i believe he was running 11's
also look on youtube i believe iceman271offroad i believe was his screen name. he posted several vids of what it could do
w8less is offline
Old 02-21-2008, 10:40 AM
5spd GT
5spd GT's Avatar
The kit is okay...
I would swap out the camshaft and valve springs for a custom set.
5spd GT is offline
Old 02-21-2008, 11:10 AM
stanguy306
stanguy306's Avatar
Have you already purchased the Holley top end kit?
stanguy306 is offline
Old 02-21-2008, 11:59 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
sounds like a decent set up..should run okay
mjr46 is offline
Old 02-21-2008, 01:14 PM
92sleeper
92sleeper's Avatar
yea i already bought everything for the motor.
Old 02-21-2008, 04:10 PM
ih8chevy
ih8chevy's Avatar
there was some guy on here had that kit and was hitting 12.60's. dunno the gears and the injector size but im assuming 24 lbs. sounds like its a pretty good kit
ih8chevy is offline
jwog666
12-27-2021 08:09 PM
flash_xx
10-16-2015 07:23 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: 306/w holley kit
