AOD to C4 swap
Old 03-02-2008, 07:48 AM
jdehn
jdehn's Avatar
Default AOD to C4 swap
Hi I have a 89 GT that was originally a 5spd car and the previous owner switched it over to an AOD. The AOD is slipping badly when I get in the gas hard and the od doesnt work so I picked up a small bellhousing c4 and converter from cook's racing in cowpens, sc. I have already ordered the correct sfi flexplate and I havethe rightshifter. I will need a dipstick tube and a kickdown cable and I'm not sure where I can pick those up. What else will I need to complete my swap? I want to have everything ready before I start. Any help will be appreciated.
Jason
jdehn is offline
Old 03-02-2008, 09:53 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: AOD to C4 swap
for the kick down cable set up...try LOKAR they specialize in such...also maybe TCI......just a guess....also you may want to think about running a external tranny cooler and you may have to get adapters and reconfigure cooler lines a little to fit the set up
mjr46 is offline
Old 03-02-2008, 10:34 AM
jdehn
jdehn's Avatar
I already have the largest tranny cooler that b&m offers. I added that when I put my new aluminum rad and electric fan. Thanks for the info on the cables.
Jason
jdehn is offline
Old 03-02-2008, 10:36 AM
mjr46
mjr46's Avatar
^^okay well your fine in that area then!!
mjr46 is offline
Old 03-02-2008, 09:52 PM
jdehn
jdehn's Avatar
Will I need a new spedometer cable or will the stock cable work with the C4?
jdehn is offline
Old 03-02-2008, 10:07 PM
mcfomco
mcfomco's Avatar
The stock cable worked on my car. Its an 86 gt. On the 89 it may be different though not sure.
mcfomco is offline
CarrieS
09-01-2015 01:00 PM
tw3ak
08-30-2005 05:01 PM
Robs5 0
07-20-2005 05:50 PM
njoverkill
06-02-2003 01:30 PM
Quick Reply: AOD to C4 swap
