Code 67
Old 03-05-2008, 04:48 PM
9tyfiveo
9tyfiveo's Avatar
Default Code 67
I recently just ran the codes because i have been having an idle problem where it idles too high for a few seconds (about 4sec @ 900-1000rpm) then finally comes down to where it should be about 200-300 less than that.I pulled a 67 with Key On Engine Off,
Looking up in my book what Code 67 Means....
"Neutralpressure switch (NPS) circuit failure, circuit open (3.0L MAP, 3.0L MAF-SFI, 3.8L SFI)"
and after, it passed. No other codes.
would this affect my idle? where can i fix this problem? what can i check? any help would be great if you know ANYTHING about code 67 or what might have caused it
9tyfiveo is offline
Old 03-05-2008, 07:39 PM
aode08
aode08's Avatar
Default RE: Code 67
[/align] Duralast / Neutral Safety Switch F409
Application: With automatic transmission Enter ZIP code above to check availability and pricing
[/align] Duralast / Neutral Safety Switch F464
Application: With manual transmission Note: Clutch pedal position
Yes it will, usually the wiring connector gets burnt by the exhaust, the sensor fails or the connector breaks.
aode08 is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Code 67
