Just did H/C/I did i screw up?
Old 03-18-2008, 05:57 PM
PJC Racing
PJC Racing's Avatar
Default RE: Just did H/C/I did i screw up?
ORIGINAL: aode08
ORIGINAL: jerod187
hey guys ive never done this before and i just wanted to know if everthing sounded good so far? i put a new holley systemmax 2 cam in with new timing chain, some ported polished, 1.94 and 1.6 valves, with heavy duty springs and retainers in and used energizer roller rockers,
my procedure, turn piston to TDC and adjusted the proper rockers then rotated adjusted other ones and so on, but i tightened the rockers by hand untill the push rod had slight resistance the tightened it 3/4 of a turn for each one but i didnt measure the pushrod length i just used stock ones, does this sound ok?
take em off one cylinder, put a black permanent marker circle on the valve tip stem(covering the whole tip,
then , do as you did, adjusting the two rockers, keep turing the engine over by hand or use the starter.
Note that the circle should have a narrow line in the CENTER of the stem, where it wore off the black marker.
Pushrod length should be measured with a solid lifter.
PJC Racing is offline
Old 03-18-2008, 09:23 PM
OnyxCobra
OnyxCobra's Avatar
This makes me cringe, sounds like things are being half-assed. I'd never run stock pushrods with stronger valve springs, i've heard of countless times where the stock pushrods turn into pretzels and F up a lot of the valvetrain. You should always check pushrod length and always check piston-to-valve clearance before assemblying an engine.
OnyxCobra is offline
Old 03-19-2008, 04:08 AM
LTnone
LTnone's Avatar
Hardened pushrods ftw
LTnone is offline
jwog666
12-27-2021 08:09 PM
11-18-2015 01:34 PM
breaking
10-02-2015 01:27 PM
09-10-2015 07:23 PM
Quick Reply: Just did H/C/I did i screw up?
