Fog Lights wiring
Old 04-04-2008, 01:23 PM
95GTgirl
95GTgirl's Avatar
Default Fog Lights wiring
I am wanting to wire my fog lights so i can turn them on and off without having to turn the main headlights on. I want to be able to just turn them on using the fog light switch. Has anyone done this before and if so how did you go about doing it.
95GTgirl is offline
Old 04-04-2008, 01:27 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Fog Lights wiring
unless you want to hack up wiring so they operate the way you want..cause in stock form they are wired to go off with the bright lights on.....so easiest way is out under the bumper..unplug them from the harness...buy a 30 amp relay and switch..or use the switch in your car....but you'll also have to unplug that and create new wiring for it..but that's the easiest way to do it
mjr46 is offline
Old 04-04-2008, 04:29 PM
OnyxCobra
OnyxCobra's Avatar
I think the easiest way is to wire them so they turn on any time the parking lights are on. Takes like 10 minutes and involves zero cutting.
OnyxCobra is offline
Old 04-04-2008, 05:12 PM
roushxteam199
roushxteam199's Avatar
This is a website that will show you how to wire them in. http://www.corral.net/tech/maintenance/foglights.html
roushxteam199 is offline
Old 04-04-2008, 06:00 PM
bbbngowc
bbbngowc's Avatar
ORIGINAL: roushxteam199
Based on the name, prolly would need instructions for a 95GT
bbbngowc is offline
Old 04-04-2008, 06:53 PM
98F150/GT
98F150/GT's Avatar
thats where i went for my 95 and worked perfectly
98F150/GT is offline
Ford_Dude
09-15-2015 03:25 PM
jaiidutch
09-14-2015 10:29 AM
cbird1177711
09-03-2015 08:43 PM
amandahchase
09-03-2015 10:09 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Fog Lights wiring
