MASS AIR FLOW problems any ideas
Old 04-06-2008, 07:23 PM
xfasteddiex
xfasteddiex's Avatar
Default MASS AIR FLOW problems any ideas
i could unhookmaf sensor start car & it willstart & run great i am told i shouldnt start with it unpluged so i bought a new one instaled it & worked like it should THEN a few days later my mileage droped off first thing i looked at was maf sensor bad again i swaped out for another new one& no workie right out of the box could i have another problem & if so what[sm=smiley35.gif]
thanks in advance
eddie
xfasteddiex is offline
Old 04-06-2008, 07:43 PM
brentloftis
brentloftis's Avatar
Default RE: MASS AIR FLOW problems any ideas
Did you reset the comp when you changed the MAF the first time? Just trying to figure out how the replacment would work for a short period of time then the same symptoms come back. Did you try the KOEO\KOER test, and any codes showing?
brentloftis is offline
Old 04-06-2008, 08:11 PM
xfasteddiex
pulled the battery cables when i done the swap both times & masair flow probmems wont show up on KOEO\KOER test my buddy works for ford but can only hook up computer for free at certant times it might bee a week before he can get to it & at 59 bucks a pop i aint gonna pay the ford house
Old 04-06-2008, 09:51 PM
brentloftis
My initial thought is the problem is elsewhere possible not related to the MAF and with it disconnected it is returning to open loop programming but again this is just a guess.
Old 04-06-2008, 10:16 PM
dudeboy
dudeboy's Avatar
^exactly.
Pull codes and see what you find...
There are ways to pull the codes without the readers... a search of this site should locate a link to one of those procedures.
dudeboy is offline
Old 04-08-2008, 09:52 PM
xfasteddiex
3rd maf sensor in 5 days thisone idlrs like it has a cam in it & kind of like krap when you unplug it it idles up 200-300 rpm & smooths out
Old 04-08-2008, 11:10 PM
lxman1
lxman1's Avatar
Soundl like you might have other problems like wiring, bad ecm or a vacuum leak.
lxman1 is offline
Old 04-08-2008, 11:25 PM
dudeboy
dudeboy's Avatar
ORIGINAL: xfasteddiex
http://www.troublecodes.net/Ford/
Or,
Joel5.0 linked to a couple of diagnostic pages in this thread...
https://mustangforums.com/m_1862384/tm.htm
find out what the ecu thinks,
dudeboy is offline
Old 04-09-2008, 09:31 AM
xfasteddiex
got these codes i have egr unhooked so i know why 33 comes up ,66 should be good as i have replaced maf 3 times in a week or so mabe ill replace it again or shoulg i try replacing the computer ??? i have no idea about 23 code
23
Throttle sensor out of range or throttle set too high - TPS
33
(O,M)
ALL - EGR did not open/ respond during test or if memory code, did not open intermittently - EVP EVR PFE
66
[align=left]Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - VAF MAF[/align]
djbigskrilla
09-20-2022 01:04 AM
Gun Jam
10-04-2015 12:10 AM
Figure8allday
08-22-2015 11:11 AM
dfw692
08-07-2015 11:53 PM
Quick Reply: MASS AIR FLOW problems any ideas
