popping noise
Old 04-13-2008, 07:33 AM
  #21
Frstgeneclipse05
Frstgeneclipse05's Avatar
Default RE: popping noise
I had a similar problem in my 89
Frstgeneclipse05 is offline
Old 04-13-2008, 07:37 AM
  #22
89mustangfive0
89mustangfive0's Avatar
what happpend what did you do
89mustangfive0 is offline
Old 04-13-2008, 09:01 PM
  #23
89mustangfive0
ok so my dad and i looked at the plugs im running and they arent seated correctly as mentioned...its stained around all plugs so tomorrow im gettint he autolites....also my number 4 plug wire had soem breaks in it ( like some cracks) so i rtv'd it and my number 7 wire was f'ed up...so im going to buy another set of the ford racing wires.....this should solve my popping problem hopefully
Old 04-13-2008, 09:12 PM
  #24
PJC Racing
PJC Racing's Avatar
Good deal, let us know how you make out.
PJC Racing is offline
Old 04-13-2008, 09:27 PM
  #25
89mustangfive0
i hope it all works out.....and i belive the driver side headers to h pipe can be tightend a weeeee more..i was afraid of snapping it
Old 04-13-2008, 09:45 PM
  #26
89mustangfive0
do you run those autolites in your car???
Old 04-13-2008, 10:01 PM
  #27
PJC Racing
PJC Racing's Avatar
Yes, same heads.
Old 04-13-2008, 10:03 PM
  #28
89mustangfive0
ok cool....also how wouldi know if my msd coil is no good??
Old 04-13-2008, 10:10 PM
  #29
PJC Racing
PJC Racing's Avatar
If the coil is not sparking at all, you can do a resistance check across the the positive and negative poles, if you have infinate resistance the coil is for sure N.G.. If the problemis intermitant you will have to see if the coil is getting a spark signal when it is not firing. If it is getting a signal and not firing (and your ground is good) the coil is N.G..
Old 04-14-2008, 10:43 PM
  #30
89mustangfive0
ok new plugs are in ( autolites) car runs muchhh better....no more popping...the popping was probably my motor sucking cold air in because those accel plugs weren seated properly
cr620
10-03-2022 10:18 PM
bjdutch2005
03-24-2017 03:38 AM
KingRando
10-02-2015 08:06 AM
MacSerio
09-27-2015 01:05 PM
gagemcc
09-22-2015 09:43 AM
Quick Reply: popping noise
