rpm gauge reading incorrect
Old 04-12-2008, 07:08 PM
89stanger1989
89stanger1989's Avatar
Default rpm gauge reading incorrect
i got the black to ground, red to 12 switch, and green to green coil wire. it could be at 6000 rpm and it will read 2000. a buddy told me it might run on 6 volts because he doesnt think the tach is for a car cause i found it in my garage. no brand either its a small 2 1/2inch.
89stanger1989 is offline
Old 04-12-2008, 07:46 PM
wrenchturner75
wrenchturner75's Avatar
Default RE: rpm gauge reading incorrect
most tachs have a switch to select a 4,6or8 cyl its possible its not on 8cyl.
wrenchturner75 is offline
Old 04-12-2008, 08:07 PM
nitrous_bob
nitrous_bob's Avatar
is there a tfi harness going to a msd box ? it must be tapped into the new harness...not the coil harness if so
nitrous_bob is offline
Old 04-12-2008, 09:22 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
which brand tach did you put on
mjr46 is offline
Old 04-12-2008, 10:25 PM
white93pony
white93pony's Avatar
bad tach is my guess
white93pony is offline
Old 04-13-2008, 12:17 AM
89stanger1989
theres no brand or switch but i'm going to try what nitrous bob said and see if it works
Old 04-13-2008, 08:54 AM
89stanger1989
yea nothing worked. this is probably for a different car maybe 4 or 6 cyl. im just going to buy a new one . thanks
Old 04-13-2008, 10:16 AM
nitrous_bob
i like shift lights better..... it's pretty much the only rpm thats important. as long as your stocker isn't broke.
plus you don't even have to look at it...bright enuff to catch out of the corner of your eye...i like a 5200 chip..by the time you actually hit the shift your about 5500 and it runs really well.
no need for a bracket either....a strip of velcro on the steering wheel base will keep it there good.
mtgldr
02-03-2024 09:00 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: rpm gauge reading incorrect
