High speed shakes
Old 04-19-2008, 10:43 AM
Muk_Mustang92
Muk_Mustang92's Avatar
Default High speed shakes
After getting the trans back together, noticed the car started to shake pretty violently at ~65 (speedo dont work). It does it no matter what gear im in, or how hard im pushing it.
Any suggestions?? Could it be something with the tranny?? Was thinking maybe loose driveshaft, but everything is tight and looks good. Kinda running out of idea's and patience with this car.
Muk_Mustang92 is offline
Old 04-19-2008, 11:14 AM
apedosmil
apedosmil's Avatar
Default RE: High speed shakes
Check the U-joint off the driveshaft if one of them went u could be getting nasty vibrations at around a speed of like 65
apedosmil is offline
Old 04-19-2008, 12:01 PM
Muk_Mustang92
It was replaced last year with the trans, could it of gotten tweaked a little taking it out and putting it back in?
Old 04-19-2008, 01:35 PM
tmajikman
tmajikman's Avatar
Well I am having the same problem, I jacked up the rear of the car and found that the tailshaft housing had a lot a play and the ds was moving a good bit which is causing my vibration.
tmajikman is offline
Old 04-19-2008, 03:27 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Could be loose driveshaft or u-joints. Could be suspension components or could be tires needed balanced. Tires would be a cheap easy thing to eliminate.
Boss_Hotrod is offline
Old 04-19-2008, 05:53 PM
aode08
aode08's Avatar
U cupped tire will also do this.
Roll your hand over the pattern, and look closely at the tread levels, they should be exactly the same, no high and low spots, or cups
aode08 is offline
mtgldr
02-03-2024 09:00 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: High speed shakes
