Steering Wheel Movement?
What would cause the steering wheel and the plasic stuff behind it, like the switch and all that stuff, up and down, 1/4"? The part that goes through the fire wall doesn't move. It used to do it about an 1" but I found a loose bolt and tightened it. Suggestions?
RE: Steering Wheel Movement?
First guess would be Tilt Steering and a tooth or two are broke or the pin is bent. Undo the 2-3 screws in the plastic stuff behind the steering wheel and move it while looking in there.
Check the pin that the tilt mechanism holds onto, I just replaced what looked to be old coat hanger wire on mine. Before this it would flex due to the wire bending etc..... replaced it with a nail so we will see how long that last.
there is more than 1 bolt that needs to be tightened..once you remove the switch assembley you can access 3 on an extension and correct torx socket I believe and the 4th is impossible if yours is anything like mine
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
