need help with axles
Old 05-05-2008, 12:09 PM
ambernwill06
ambernwill06's Avatar
Default need help with axles
hi i have a 7.5 rear end out of a aerostar that i am pulling the right side shaft out for my mustang. two problems i dont know how to get the shaft out and also the drums on the aerostar and the mustang are two diff. sizes can i take th back-plate and all off the aerostar and put it on my mustang? thanks for your help.
ambernwill06 is offline
Old 05-05-2008, 01:32 PM
1fast86
1fast86's Avatar
Default RE: need help with axles
Remove the inspection cover off the housing, remove the bolt that holds the pin in (5/16" socket,wrench), remove the pin from the carrier, push axles inward toward chunk, and remove c-clip. Pretty simple. If the axle from the Aerostar and Mustang are the same length and they both are 7.5 rears [:'(], swap them out. I would use the Mustang drums though. Instead of all that why not put an 8.8 in?
1fast86 is offline
Old 05-06-2008, 12:11 AM
ambernwill06
i would but i have this rear end and money is hard to come by right now. if i can get this one to work i might as well. thank you for the reply.
Old 05-06-2008, 01:40 AM
raven_ghostwolf
raven_ghostwolf's Avatar
ORIGINAL: ambernwill06
Yes you can but make sure you swap out both sides. And unless you have already converted to 5 lug your still going to need one more right side axle.
ORIGINAL: 1fast86
The Aerostar 5 lug, is the same as using the Ranger rear for a 5 lug conversion. But the ranger uses 9" drums so it is a direct swap to the Mustang's 9". He didn't say what is car has, he might already have the 8.8 just doing a 5 lug conversion?
raven_ghostwolf is offline
Old 05-06-2008, 09:39 AM
ambernwill06
no its the 7.5 but im just going to get the ranger drums because the components for the aerostar are all rusted up.
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
lincolnshibuya
09-24-2015 10:46 PM
09-24-2015 09:18 PM
09-10-2015 08:39 PM
Quick Reply: need help with axles
