347 w/ Main Support and oil dipstick problems
Old 06-18-2008, 02:32 PM
BlessedHellride
BlessedHellride's Avatar
Default 347 w/ Main Support and oil dipstick problems
I got around to putting the dip stick tube and dip stick into the block today and I'm running into something with the dipstick. Am I running into the main support with the dipstick or what do you guys think. I didn't know that I couldn't use a factory pan with a main support and have these problems or I would have bought a different pan and dip stick. Let me know something guys.
BlessedHellride is offline
Old 06-18-2008, 03:42 PM
jtmustang
jtmustang's Avatar
Default RE: 347 w/ Main Support and oil dipstick problems
i am not sure what u are hitting . as far as the main support i dont know if u can run it with a stock pan.
someone who has a ms will chime in for more info.
jtmustang is offline
Old 06-18-2008, 04:55 PM
woodsy
woodsy's Avatar
you got a cheap ebay girdle without a hole for the dipstick? If so thats your problem, as for a stock pan, they work fine, if anything gotta play with the curve that goes around the oil pump
woodsy is offline
Old 06-18-2008, 05:11 PM
BlessedHellride
I did indeed buy one of the cheap girdles without the provisions for the dip stick. I got it mounted ok with a little bit of clearance issues that a little deburring bit didn't take car of around the oil pump housing. I never thought in all my world that it would have came to this. I did bend the crap out of the dip stick at the end of it and got it cobbled up to go in and out of the pan, but I am not satisfied with it at all. It got me insanely pissed off to the 10th power. If I would have known that it would have caused these problems, I would have went a different route. First time I built an engine with a main support. My ignorance is truely the fault of this problem. Wished that some of these "internet" super engine builders would have let me know something before I went this far with the build.
Old 06-18-2008, 05:26 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I HAVE a trick flow one that went on a previous motor and we clearanced it around the pump housing and bent the dip stick appropriately
mjr46 is offline
Old 06-18-2008, 05:31 PM
BlessedHellride
I talked to the Summit tech line about my problem when it first reared it's ugly head today and the guy told me over the phone that if I would have gotten a Trick Flow main support, that they come with aprovision or a hole in the support for the oil dip stick. Did yours have a hole in it or no?
Old 06-18-2008, 05:34 PM
mjr46
mjr46's Avatar
it may have but never paid to much attention to it as I used a moroso 7 qt pan with dip stick provision in the pan
mjr46 is offline
Old 06-18-2008, 05:50 PM
BlessedHellride
I asked the guy at Summit about that also. He said I would run into the same problem with the dip stick provision in the pan. I felt like screamin curse words at him but I kept my composure and went ahead and put a battery on the car and wired up the Ford Racing mini starter and got it to spin the engine over correctly. I ran the valves on it last night. All I got left to do now is pre oil it, drop in the MSD dizzy and 6AL box and it will be fire in the hole.
Old 06-18-2008, 05:56 PM
mjr46
mjr46's Avatar
summit tech guys =[&:].....I didn't run into any issues with my moroso pan until I added a dss main support and pr tray and all it was was a little clearancing to do and pan mod with a hammer and torch
mjr46 is offline
EASTIDEE123
09-15-2015 11:08 AM
EASTIDEE123
09-14-2015 03:52 PM
marine_2003
09-26-2005 10:11 PM
marine_2003
09-18-2005 03:52 PM
brutal_gt
07-09-2005 06:00 PM
Quick Reply: 347 w/ Main Support and oil dipstick problems
