backfiring through intake and losing power
Old 06-30-2008, 09:44 PM
ShadyZealot
ShadyZealot's Avatar
Default backfiring through intake and losing power
Finally got the roller that i bought up and running. it has a stock 302 with explorer intake. Seems to run great just idling. FP is set at 36 w vaccume off. Timing is right around 12. It even pulls healthy at WOT. a bit slower then what i expected but it goes up through the RPMS no problem.
However every now and then while driving it when i give it just like 25% throttle it will pop really bad and lose all power. It will feel like it just wants to die. If i were to go WOT it clears up tho.
The roller was sitting for a while before i got it. Do you guys think its a possibilty that the lines or the pump has gotten gunked up? only FP gauge i got is rail mounted so i havent had the chance to see if the FP is dropping off when it does this. Gonna get some line so that i can though. Thats only idea i got. Anything else you guys might have in mind please let me know.
It is an AOD car, and i dont have the speedo up but the VSS doesnt control any kind of fuel delivery does it
ShadyZealot is offline
Old 06-30-2008, 10:27 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: backfiring through intake and losing power
timing is probably too far advanced
AdderMk2 is offline
Old 06-30-2008, 10:30 PM
ShadyZealot
did the same thing when i had the timing at 8. Bumping it to 12 didnt chang it
Old 06-30-2008, 10:56 PM
AdderMk2
Banned
AdderMk2's Avatar
you advanced it further.... duh
your distributor is probably in wrong, or perhaps your balancer is not straight
AdderMk2 is offline
Old 07-01-2008, 12:13 PM
ShadyZealot
What do u mean by my balancer is not straight?
No way timing is too far advanced. it runs fine WOT does not ping at all
Old 07-01-2008, 12:41 PM
AdderMk2
Banned
AdderMk2's Avatar
are you aware that there is less timing at WOT then part throttle cruising??
AdderMk2 is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
04stangman
09-17-2015 01:45 PM
vintageaion
09-08-2015 10:45 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: backfiring through intake and losing power
