crank damper/flywheel help
Old 07-07-2008, 01:09 AM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
Default crank damper/flywheel help
what is the corrct way to install the flywheel in relation to the damper? im helping my brother build his motor (when i took mine off i just marked it and put it back on. never paid it much mind). its a 94 motor, 50oz imbalance. should the two weights be even with each other or 180* apart? thanks a lot guys.
sn95_331_GT_ yellow is offline
Old 07-07-2008, 02:11 AM
Gary H
Gary H's Avatar
Default RE: crank damper/flywheel help
They only go on one way. The flywheel holes arent evenly spaced and the balancer has to line up with the keyway.
Gary H is offline
Old 07-07-2008, 07:55 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
holes on flywheel are offset and balancer slides into keyway..can't get it wrong
mjr46 is offline
Old 07-07-2008, 11:12 AM
sn95_331_GT_ yellow
ok good. thanks a lot guys.
svfetter
10-05-2015 11:39 AM
jessicarabbit
09-25-2015 12:41 PM
SteelerNation82
09-16-2015 07:11 AM
EASTIDEE123
09-14-2015 03:52 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: crank damper/flywheel help
