T-5 to C-4 trans swap
Old 08-01-2008, 08:16 PM
mikekx65
mikekx65's Avatar
Default T-5 to C-4 trans swap
I'm looking at a C-4 trans on ebay. It came out of a 1976 mustang and has a 26 spline input shaft. I know i will need a Stall converter and different flywheel....will i need a new bell housing to do the swap? And is the 26 spline compatable or will i have to pull my T-5 and see what shaft it has?
mikekx65 is offline
Old 08-01-2008, 08:30 PM
LX 90
LX 90's Avatar
Default RE: T-5 to C-4 trans swap
You will need
Flexplate 157 or 164 tooth
The bellhousing that matches either of the flexplates
torque converter
dipstick
and a crossmember
and yes 26 spline is what u have
LX 90 is offline
Old 08-01-2008, 08:40 PM
mikekx65
mikekx65's Avatar
Is either one of the flex plates better than the other? Where can i pick up a cross member? Without the cost of the trans itself what am i looking at price wise to do the swap?
mikekx65 is offline
Old 08-04-2008, 02:35 PM
calfroper_06
calfroper_06's Avatar
mike i actually am converting my mustnag from an auto to a t-5 i have most the stuff you need minus the crossmember. have a tci 2800 stall the stock converter a trans cooler and tranny,. if interest message me.
calfroper_06 is offline
Old 08-04-2008, 02:48 PM
uedlose
uedlose's Avatar
your stock cross member will work you will need to cut the weld on the ends where the bolt goes and move the cross member all the way forward. or you can just elongate the holes more to the frontother then that it works tight but works.a 157 flywheel will let you run a smaller bell and that means more room to work on stuff. I have run both and Iprefer the small.
uedlose is offline
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: T-5 to C-4 trans swap
