water/moisture in intake
Old 08-24-2008, 08:24 AM
jssblues
jssblues's Avatar
Default water/moisture in intake
when i take the egr off or the upper intake there is lots of moisture in the egr passageway
is this normal???????
jssblues is offline
Old 08-24-2008, 09:19 AM
enoughsaid
enoughsaid's Avatar
The coolant passage from your upper is what creates that moisture. As long as its not excessive you should be fine. Maybe try to tighten down the bolts that pass through your throttle body. Also I see you ported your intake. I assume you replaced the gaskets between tb and egr. The new gasket will absorb some moisture at first but will go away.
enoughsaid is offline
Old 08-24-2008, 10:32 AM
jssblues
jssblues's Avatar
my coolant lines on throttle body are not even hooked up
jssblues is offline
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
Dokilar
15
10-16-2015 08:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: water/moisture in intake
