Mach 1
Old 10-29-2003, 11:02 PM
jcowboys8
jcowboys8's Avatar
Default Mach 1
<LABEL id=HbSession SessionId="3092152034"><IMG src=smileys/smiley7.gif border="0"></LABEL></P>
<LABEL SessionId="3092152034">Help!!</LABEL></P>
<LABEL SessionId="3092152034">Frustration has set in. I have a 2003 Mach1. When I switch from 1st gear to second it feels notchy. The rest of the gears go in smooth. My dealer says its normal. Is it?</LABEL></P>
jcowboys8 is offline
Old 10-30-2003, 12:07 AM
Monch
Monch's Avatar
Default Mach 1
i don't think its normal, the shifter might be tweaked a bit, i test drove one a month agoand it shifted just fine. i wasn't kind to it during the test drive either much to the dismay of the salesman who rode along with me.</P>
Monch is offline
Old 10-30-2003, 12:14 AM
vfast
I ♥ Acer
vfast's Avatar
Default Mach 1
get you a pro 5.0 or tri-axle shifter..
vfast is offline
Old 10-30-2003, 12:23 AM
n2o44
n2o44's Avatar
Default Mach 1
this is a know **** with those trans , tremmec has a fix, drain it and put regular atf in there , ford puts syn, and fill it exactually 3.2-3.5 qt. ford over fills them . there is alot of people complaining about this , its a know issue for a while . the dealer will bs you cuz they dont want to do it under warrenty . people are trying to get togather to make ford fix this , i swear i dont know of anyone that saids there car does not do that that have the trans , do a search on stang net<edited><editID>n2o44</editID><editDate>37923.9329976852</editDate></edited>
n2o44 is offline
1BAD3V
Tennessee Regional Chapter
10-06-2016 12:12 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
Sixer4Life
09-29-2015 07:03 PM
Quick Reply: Mach 1
