Water pump rotation - MustangForums.com
Old 11-04-2015, 01:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Old 02-28-2009, 11:47 PM   #1
Ford Drag Team
Ford Drag Team's Avatar
Default Water pump rotation
I was looking for an aluminum water pump and I noticed that some are for "79-85's w/ v-belt pulleys" and "86-93 w/ serpentine pulleys"....
...My '82 GT has a serpentine system, not a v-belt, so that's confusing to me.
Do all serpentine systems have a reverse rotation water pump?
What year did Ford start using that?
Also I have another unrelated question while I'm here.
I'm removing the A/C and Smog Pump and I want to remove the power steering pump as well and block the fittings in the rack.
I know of someone who has done this and he's been driving his car 9 months out of the year for the past 2-3 years with no problems.
I know this isn't advisable and I should just wait until I get a Flaming River Manual rack.
What's the worst that could happen if I did block off my power rack as stated?
Do they dry up and stop working or anything like that?
Did any Fox Body's have a manual rack from factory?
Thanks guys
-Joe
Ford Drag Team is offline   Reply With Quote
Old 03-01-2009, 12:24 AM   #2
AdderMk2
Banned
you cant just block off the fittings, you have to loop a line between the two ports
AdderMk2 is offline   Reply With Quote
Old 03-01-2009, 10:02 AM   #3
Ford Drag Team
Yeah you're right, that's what I meant to say.
Have you done this, and if so how long do they last?
What's the worst that could happen to it, if it does fail?
Anyone know about the water pump question?
Thanks for the reply man
Old 03-01-2009, 10:45 AM   #4
Ford Drag Team
If someone here has a 302 w/ a serpentine belt that has the Crank/Water pump/Alternator only and can take a picture of the belt routing and/or give me the size of the belt used that would be great.
I want to get rid of everything except for the crank/waterpump/alternator, but I need to figure out which direction my water pump should rotate and what tensioner I need to use, and if I need to relocate the alternator and get different brackets.
So if anyone has a pic or can give me a list of parts or any tips on this, I would greatly appreciate it.
Thanks
edit:
car is a 1982 GT w/ 302 H.O. (serpentine)
It currently has a smog pump,A/C, and power steering.
If you need any more info I can post a reply.
Old 03-01-2009, 11:55 AM   #5
AdderMk2
Banned
not that its going to help much... but
also, a manual steering system isnt that expansive.
To run your belt like mine, you will need to get an aftermarket alternator bracket with a turnbuckle style tensioner
Old 03-01-2009, 01:12 PM   #6
luckythirteen13
luckythirteen13's Avatar
pic in my sig of crank, water pump and alt.
luckythirteen13 is offline   Reply With Quote
Old 03-01-2009, 01:36 PM   #7
mustangmike33
does it matter which way the alternator spins to charge. cause if you ask me your set-up looks different from the one im running. so did you change the pump or what?
mustangmike33 is offline   Reply With Quote
Old 03-01-2009, 07:28 PM   #8
AdderMk2
Banned
as long as the alternator has the ribbed side of the belt on it, it doesnt matter where its mounted, it will spin the same direction
Old 03-02-2009, 05:33 AM   #9
Ford Drag Team
Adder,
What tensioner pulley are you using for your set up?
My Uncle has a Capri w/ the same set up as you and I was wondering how he used the stock (reverse rotation) pump.
I would like to utilize the tensioner pulley that I have, otherwise I have 2 options: #1 get a ribbed water pump pulley and the old style (regular rotation) pump and do away with the tensioner pulley altogether, or go with the old V-belt system with the old style pump.
Is your tensioner pulley grooved?
I'm hitting up the junkyard this morning to see if I can find a ribbed water pump pulley.
I think that '79 LTD/Full size Fords have the pulley that I need, but I'm going to check everything I run across until I find one.
I checked ebay, Summit, Jegs, Autokrafters, etc...no one has it.
I did find an underdrive pulley set w/ a ribbed water pump pulley, but that was it.
That kit was to convert from the v-belt to serpentine using the regular rotation pump.
Thanks for all of your help everyone.
edit:
Basically if I can get the same set-up as you, I would only need a ribbed tensioner pulley and a belt. That would be cheaper and less hassle.
What size belt are you using?
Stock diameter pulleys??
How does it provide tension from under the belt as opposed to on top of the belt like stock?
Did you flip the spring around as well?
Thanks
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 05:23 PM
2014 convertible water drains jerrytubes 2005-2014 Mustangs 2 10-23-2015 01:11 PM
Terminated Whipple GT battles '13 GT500 on E85 Bokeo Street/Strip 6 10-10-2015 09:28 PM
Original Owner 1970 Mustang b8checker Classic Mustangs (Tech) 8 10-08-2015 01:55 PM
Original Owner 1970 Mustang b8checker New Member Area 3 09-30-2015 08:11 AM
1990, 50, 8693, changing, ford, gt, line, mustang, pulley, pump, regular, roblems, rotation, routing, smog, water
