Shifting Problem
Old 03-06-2009, 03:59 AM
SJPajak
SJPajak's Avatar
Default Shifting Problem
I have been driving my 91 gt for about 7 months now. daily driver, pro 5.0 aftermaket shifter, aftermarket clutch but not sure what brand. over the past couple of months, it has been harder and harder for me to change each gear 1-2 2-3 3-4 4-5. i have to force the damn shifter into gear everytime. anyone got anything
SJPajak is offline
Old 03-06-2009, 04:55 AM
302army187
302army187's Avatar
re-adjust your cable, prob not disengading the clutch all the way.
302army187 is offline
Old 03-06-2009, 06:11 AM
Timspony
SVT Section Moderator
Timspony's Avatar
Sounds right to me ^^^^
Timspony is offline
Old 03-06-2009, 06:27 PM
SJPajak
SJPajak's Avatar
ok, any ideas on how to do that. what tools do i need? anyone that can help would be great thanks
SJPajak is offline
Old 03-06-2009, 07:50 PM
Big_Steve
Big_Steve's Avatar
your 91 as is mine supposed to have an automatic cable adjuster, but mine don't work. You can try pulling up on the clutch pedal as had as you can then push the pedal all the way down and it should click, you continue to do that till it stops. If that dose not work then jack up the car, get underneath and adjust the cable at the clutch fork.
Big_Steve is offline
Old 03-06-2009, 08:21 PM
wowvfast
wowvfast's Avatar
I bet your quad is cracked due to extra pressure from an after market clutch
also you may have bent your clutch fork...do you have a firewall adjuster?
wowvfast is offline
Old 03-06-2009, 09:28 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check your cable, common prob was they'd stretch as the strands unwound and broke 1 by one catching on the internal sheath until finally the cable would snap, but slowly engagement would get worse and worse before snapping occured
mjr46 is offline
Brandonfilipponi@yahoo.com
09-12-2015 11:39 AM
Mustangmalo
09-06-2015 05:22 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Shifting Problem
