new mods now car wont run
Old 03-16-2009, 03:40 PM
  #21
frost1357
frost1357's Avatar
yea ive done everything that everyone has told me to do. and ive restabbed the destrib a few times nothing has changed
frost1357 is offline
Old 03-16-2009, 04:27 PM
  #22
PJC Racing
PJC Racing's Avatar
Operator error.... Restabbing the distributor, Is the car at TDC? Are you sure? You could be 180 off (top of the exhaust stoke). Where is the #1 cylinder terminal at when you stab the distributor? You can't just have #1 anywhere, it needs to be at just before 12 o'clock when you are looking at it from the front of the car (#1 will be toward the intake). This needs to be oriented corrected so the Hall Effect Sensor (TFI) can detect what cylinder to send the injector signal.
PJC Racing is offline
Old 03-16-2009, 06:36 PM
  #23
Compression
Compression's Avatar
Did you convert the heads to stud mount rockers. If so you may have the valves adjusted wrong causing them to hang open.
Compression is offline
Old 03-16-2009, 07:34 PM
  #24
frost1357
frost1357's Avatar
yea the rotor is pointin right near the 12o'clock mark
no the new rockers are aluminums ones from ford racing stock style mounting
someone told me it may just need to be turned at a shop
Old 03-16-2009, 08:01 PM
  #25
PJC Racing
PJC Racing's Avatar
No, if it's running like crap and it was running fine before, you missed something. It does not need to go to a shop to be tuned.
Again, what about TDC (right front cylinder)? Have you run KOEO/KOER tests? Fuel pressure?
Old 03-16-2009, 08:08 PM
  #26
Slo5oh
Banned
Slo5oh's Avatar
Take out the spark plug, put your finger over the hole and feel for compression. Verify you are on the right cylender for your 12 o'clock rotor position. You could be 180* out.
Im not familear with ford firing order but with sbc its #1, Probably the same.
Slo5oh is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
bluebeastsrt
08-22-2015 07:29 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
J.casone400
08-07-2015 08:40 PM
Quick Reply: new mods now car wont run
