90 GT - Timing chain replacement
Old 03-25-2009, 09:10 AM
PONYBOY_90GT
PONYBOY_90GT's Avatar
Default 90 GT - Timing chain replacement
I'm attempting to chain out my timing chain on my stang. I have only few a questions.
1 - With only 72,000 on the clock, should I do this. The reason I'm asking is I'm fixing to install a new water pump, aluminum radiator, all new hoses, 130A
alternator, fan, etc.. I have the whole front part of the motor off and while I was thinking while I'm this far, change the timing chain. But if I don't have to I won't, the car runs excellent as is ( bone stock ) except for headers, gear, C&L meter, cold air intake & MSD ingnition.
2 - If I decide to install a new timing chain, does the oil pan need to be dropped. My buddy was suggesting that along with possibly raising the motor up some.
If I could get some feedback I would greatly appreciate it. Thanks
PONYBOY_90GT is offline
Old 03-25-2009, 09:25 AM
Portmaster
Portmaster's Avatar
If all you are doing is replacing the water pump the front cover doesn't have to be removed. If you pull the cover I would replace the chain but the only reason to pull the cover would be for a cam change or Chain Swap. Personally I've never dropped the pan to remove or install the front cover. I have a way of rolling them back in.
Your 90 Model should have a Good double roller chain in it already and if it were me I'd wait until I did a Cam swap before replacing that Chain. I've seen these things with 200K+ on the clock with the stock chain in place. If the timing cover comes off for any reason I replace the chain. Timing Chains are cheap. Putting a new one in is just good sence. If I have over 10K miles on one of mine and decide to do a Cam swap I'll put in a fresh chain.
Portmaster is offline
Old 03-25-2009, 12:31 PM
PONYBOY_90GT
I have'nt touched anything on the timing cover yet. My question was IF I do a timing chain replacement will the oil pan need to be dropped during the process of a timing chain replacement.
Old 03-25-2009, 01:02 PM
Slo5oh
Banned
Slo5oh's Avatar
short answer no
Slo5oh is offline
Old 03-25-2009, 03:16 PM
PONYBOY_90GT
that all I needed slo5oh......gracias
Old 03-25-2009, 03:37 PM
PJC Racing
PJC Racing's Avatar
Be prepared for oil leaks unless you are going to change the cover/crank seal and the area where the pan seals to the cover. You really do not need to change the chain.
PJC Racing is offline
Old 03-25-2009, 04:44 PM
Portmaster
Portmaster's Avatar
Sorry I wasted your reading time. I'll remember to give you the short answer next time.
Old 03-25-2009, 07:32 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
70k is nothing, leave the chain alone for now
mjr46 is offline
Old 03-25-2009, 07:40 PM
Modular_Madness96
Modular_Madness96's Avatar
Another FOOL and his money part ways...
Modular_Madness96 is offline
Old 06-07-2009, 04:33 PM
Pony 5.0
Pony 5.0's Avatar
snippy little noob!
Pony 5.0 is offline
djbigskrilla
09-20-2022 01:04 AM
mirandaandjimmy
11-16-2015 08:51 AM
rocket22
08-28-2015 07:08 PM
1st 4 eyed fox
08-24-2015 06:56 PM
ding56
08-14-2015 02:40 AM
Quick Reply: 90 GT - Timing chain replacement
