Clutch Cable?
Old 04-21-2009, 06:43 PM
87chp
87chp's Avatar
Originally Posted by Tony71502
New OEM cable, stock quadrant(which is adjustable if you know how), ford HD clutch, and 3.08 gears... I could chirp it every time I wanted to.
There are a couple things that could be affecting your ability chirp em.
1) You have tires with a decent bit of traction and the amount of power your stock 5.0L is putting out can't chirp the tires. Chirpin' em is basically traction loss...
2) You are not shifting fast enough, period.
3) Maybe your 5.0 is old and worn, and not producing enough power to chirp it.
4) Your clutch is slipping.
Thanks for giving me a straight forward answer and not roasting me like some others.
87chp is offline
Old 04-21-2009, 08:39 PM
88_5.0
88_5.0's Avatar
As far as your cable goes, are you having trouble putting it into gear or grinding between gears? If not your cable is probably within adjustment and shouldn't effect your gear chirping.
88_5.0 is offline
Old 04-22-2009, 03:16 PM
87chp
87chp's Avatar
I have minimal difficulty switching gears, but no grinding.
87chp is offline
Old 04-22-2009, 03:41 PM
ryan_89_mustang
ryan_89_mustang's Avatar
Well I have a stock clutch which slips sometimes, stock gears, and my engine is pretty beat, but I can chirp the tires when I shift fast. The thing is if you can get it in to gear fast enough and there is no slip you should be able to chirp em. The cable is used to get it into gear only, does not affect how the clutch clamps down.
ryan_89_mustang is offline
Thunderball
15
11-22-2015 11:49 PM
kevsgt
10-09-2015 10:12 PM
breaking
10-02-2015 01:27 PM
Explosive
10-02-2015 07:45 AM
junior04
09-28-2015 10:53 AM
Quick Reply: Clutch Cable?
