engines codes
Old 05-18-2009, 01:06 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
Originally Posted by smacked1
is this the one you're using, also bump
yeah, you don't really need it to get the codes like these guys are talking about.
It is nice to have a book with directions though.
Also, I glanced over the link and didn't see anything about the wiggle test. That test is one of the great advantages over GM diagnostics.
TrimDrip is offline
Old 05-18-2009, 01:27 PM
smacked1
smacked1's Avatar
Originally Posted by topless91gt
all you need is a paper clip to use as a jumper. the diagram shows you how to use the jumper to make the check engine light flash the codes. Its simple.
http://sbftech.com/index.php/topic,2471.0.html
thanks alot im going to try this when i get home, a fellow member pmed me the same info thanks, i just figured if the code reader was cheap might as well get one to save me time counting lights but ima try it the manual way
thanks everyone
smacked1 is offline
Old 05-18-2009, 01:28 PM
smacked1
smacked1's Avatar
what is this wiggle test you speak of? im going to google it now
smacked1 is offline
Old 05-18-2009, 02:04 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
it allows you to find a bad connection by the tester beeping when you shake sensors and what not under the hood. (i guess it could help find a vacuum leak too)
I was having cold start issues with my car but, no code was showing up for the ect sensor. I ran the wiggle test to find it had a bad connection. I put some contact grease on the sensor plug and it was fixed.
TrimDrip is offline
Old 05-18-2009, 02:09 PM
smacked1
smacked1's Avatar
good deal thanks alot for the help, i'm going to post back as soon as i run this test =)
smacked1 is offline
Nick Oliver
10-17-2018 04:22 AM
Pyrate Dave
09-10-2015 07:30 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
zanemoseley
09-06-2015 12:58 PM
zachary1988
09-04-2015 03:04 PM
Quick Reply: engines codes
