Temp guage fluctuation
Old 05-27-2009, 07:45 PM
Lx88Notch
Lx88Notch's Avatar
Default Temp guage fluctuation
ok here goes, 92 notch, 180 deg thermo (new and tested it before i put it in), new temp sender. and checked wires for any pinching, etc.
problem: temp gauge goes to the second bar (stock gauge) and then shoots to middle within seconds, stays there, then goes back down after a few minutes. now the funny thing is it will also shoot back down if i take a left or right turn where the body rolls. and then shoot back to half. any suggestions on this?
Lx88Notch is offline
Old 05-27-2009, 07:50 PM
67mustang302
67mustang302's Avatar
Check the system for air.
67mustang302 is offline
Old 05-27-2009, 07:55 PM
Lx88Notch
Lx88Notch's Avatar
i got an aftermarket housing with a screw on top, so i guessed to unsrew that and let some fluid out to bleed it (not sure if thats right) and also ran it cold without the rad cap on to make sure the pump was moving.
Old 05-28-2009, 07:10 AM
gambit90lx
gambit90lx's Avatar
Default temp gauge
my gauge will got up to the first notch and just stay there and then go back down to like when the car is off...it never gets up past the first notch now and it just started that when my water pump went bad...what do i need to look for? same thing as his is it air possibly?
gambit90lx is offline
Old 05-28-2009, 07:21 AM
AdderMk2
Banned
AdderMk2's Avatar
park the car on a steep hill facing upwards. allow it to cool off.
once cool, run it at idle with the cap off. the air will naturally make its way to the highest point in the system (now that you are parked on a hill, its your radiator)!
AdderMk2 is offline
Spiral534
10-06-2015 04:31 PM
AMAlexLazarus
AmericanMuscle.com
09-23-2015 01:14 PM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Temp guage fluctuation
