what valve covers will fit
Old 05-29-2009, 02:15 AM
AYEOH5.0
AYEOH5.0's Avatar
Default what valve covers will fit
my engine still has the stock valve covers which are just hideous. im looking for new valve covers but i dont know which will fit under my holley intake. latemodel resto has sooooo many different kinds that i really dont know which ones to look for. thanks in advance for the help.
AYEOH5.0 is offline
Old 05-29-2009, 02:28 AM
primetime5.0
primetime5.0's Avatar
I always thought the canton ones looked nice, they state they fit under stock intakes
primetime5.0 is offline
Old 05-29-2009, 02:37 AM
AYEOH5.0
AYEOH5.0's Avatar
will those fit if i upgrade to roller rockers? i think whoever had the car before me put the stock rockers back on when they put the h/c/i on ><
AYEOH5.0 is offline
Old 05-29-2009, 02:41 AM
primetime5.0
says they clear most rockers
Old 05-29-2009, 02:52 AM
AYEOH5.0
AYEOH5.0's Avatar
valve covers are a easy installation right? should i buy new valve cover gaskets also?
AYEOH5.0 is offline
Old 05-29-2009, 03:35 AM
primetime5.0
valve covers are simple, I suggest buying some ford reusable gaskets..
Old 05-29-2009, 03:06 PM
92tealcp
92tealcp's Avatar
Default Valve covers
Rollers will not fit a stock cover unless you remove the oil fill baffle, but then that makes a whole other problem. Talls will not fit under a stock manifold unless you get an intake spacer kit to raise the plenum higher. plus most aftermarket covers have no provision for an ol fill you must make your own. Ford has a nice replacement cover for a 5.0 as does TFS and Canton.
92tealcp is offline
Old 05-29-2009, 09:19 PM
primetime5.0
its cake to get stock ones to clear RR's, I made my own baffle and it works fine.
01GTon18s
10-13-2015 04:44 PM
Ipaman
09-22-2015 07:01 AM
LivingInThePast
09-16-2015 12:20 PM
prophotog
09-15-2015 08:38 AM
aleit2013
09-04-2015 11:58 AM
Quick Reply: what valve covers will fit
