94 GT issue
Old 06-10-2009, 05:59 PM
TyLawrence
TyLawrence's Avatar
Default 94 GT issue
I am looking at buying a 94 GT, however the dashlights or the wipers work. The guy said some of the fuses are not getting power. Anyone know what the issue is and how to fix it?
TyLawrence is offline
Old 06-10-2009, 06:04 PM
dv3
dv3's Avatar
check the plug on the headlight switch for the dash lights ...that plug gets hot and melts causing it to short ...$25 dollar part
might also cause the wiper fuse to blow ..not sure ...if not it could also be the multifunction switch on the column for that
dv3 is offline
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you'll have to get a wiring diagram of both those circuits , plain and simple no guessing will suffice for proper troubleshooting
mjr46 is offline
Old 06-10-2009, 06:05 PM
TyLawrence
TyLawrence's Avatar
Do you know where i can get the wiring diagram at?
Old 06-10-2009, 06:08 PM
dv3
dv3's Avatar
mjr46 is right but its easy to check that plug and a very common problem ...so i would start with that ...4 screws and you will know if thats at least part of your problem
dv3 is offline
Old 06-10-2009, 06:10 PM
dv3
dv3's Avatar
should be a diagram in here ....http://sbftech.com/index.php/topic,311.0.html
dv3 is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
12-08-2015 04:37 PM
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
Bokeo
10-10-2015 08:28 PM
Quick Reply: 94 GT issue
