Power loss, hesitatation, sputter, chug
Old 03-20-2016, 08:46 PM
  #171
zdk
zdk's Avatar
Originally Posted by cholericfc
The things that I replaced, i did in fact need, all besides the fuel lines.. fan and clutch were inevitable.. The car still runs iffy... But I agree with you, I should diagnose a little more... and it would help me out in many ways.
I did in fact look at the spark plugs, when I replaced them, and they looked fine - gaps were still good, no deposits, wear, or fuel fouled.
My next form action is to get my mechanic to run codes.
I had the same problem on my 1994 mustang gt I ended up cleaning the maf and iac sensor with crc sensor cleaner and it solved my power lag. My car has more power and throttle response now since the entire time I have owned it.
zdk is offline
Old 11-02-2017, 10:06 AM
  #172
Jimmy415
Jimmy415's Avatar
No, I gotchya man. A lot of these parts I just WANT and don't need. hah That's why I got them. When you have money to throw around it just works that way.
But, the problem is NOT easy to find on the internet. The problem is not easy to figure out. Something funked up is going on.
Also, you should read, because I've fixed a lot of problem areas while upgrading others. I bought a sensor kit from 50resto and only half of the sensors are ON. The other half are boxed and sitting around for the future if their needed.
Been following your posts for a while but i've got the same problem but on a 2002 super crew I have replaced everything and still have the problem if you figure out what it ends up being please let me know im on the verge of just getting rid of my truck and getting another one but i have to much money in it now to try
Jimmy415 is offline
Old 11-30-2017, 03:36 PM
  #173
fl1a
fl1a's Avatar
Posted by mistake, sorry.
fl1a is offline
Old 01-06-2018, 02:57 PM
  #174
joefloatin1
joefloatin1's Avatar
Question Can you explain ?
[QUOTE=cholericfc;7135475]hahaha. I found out the answer to the riddle. Here's the short story:
Recently, my vacuum gauge has been decreasing.. It ran at 5-7 the other day right as my brakes pedal was hard as a rock. It sounded like a cat hissing underneath the hood. Long story short....I found out the following yesterday:
Thank you for responding about how you fixed your car . But I am wondering how you came to find out there was an Internal leak in your brake Booster? ........... I am having a hard time figuring out whats going on with my engine having issues with back firing ,rough Idle, loss of power and no response to giving it gas , almost like i didn't hold my pedal to the floor but I did.... Well I also remembered that last time my car was running perfect but once I hit the brakes and it felt like they were manual not power brakes. The pedal was hard as a rock and I almost hit the car in front of me. I am not positive if I hear a hissing sound but I honestly think the booster may have went bad. If this sounds like it might be could you please let me know if this sounds familiar to you ..............""""" 1.) Theirs an internal vacuum leak inside the brake booster."""""
joefloatin1 is offline
Old 01-11-2018, 10:45 AM
  #175
wbrockstar
wbrockstar's Avatar
[QUOTE=joefloatin1;8611846]
The first thing to do is check the vacuum hose & check valve on the brake booster. Check the hose for a leak or clog.If its leaking,it'll create a vacuum leak which can trigger the rough idle & other symptoms you listed.A clog will cause no power assist to the brakes because of the vacuum source being cutoff to the booster.
The check valve is pushed into a rubber grommet on the front of the booster or its inline with the brake booster vacuum hose itself. Remove the valve and try blowing through both sides of the valve.Air should only pass through the booster side of the valve towards the vacuum tree or intake,but not the opposite direction. If air passes in the opposite direction or doesn't pass through either side of the valve,its defective.
This is a couple of quick tests you can do.The li​​​​​​nk at the bottom is the longer version.
(Testing the booster)
1) We use a vacuum gauge to check for an adequate vacuum. The vacuum at the brake booster should be around 16-20 inches. Insufficient amounts can result from a restricted source and sometimes engine running problems. For instance a pluggedcatalytic converter can lower engine vacuum and result in poor brake booster performance. A bad vacuum leak in the intake may also cause a lower vacuum.
2) A leaking brake booster may also cause an engine to run badly. Leaks in the brake booster provide a vacuum leak to the engine. One quick test for leakage, is to turn the engine off and press the brake pedal. If the pedal still has one or two assisted applications before getting hard to press, likely no leak exists.
3) Another simple test is to apply the brake pedal several times without the engine running, to exhaust the vacuum. After the pedal becomes hard to push, hold it down and start the engine. A good booster, with an adequate vacuum will cause the pedal to drop slightly. This is because the booster greatly increases pressure applied by the pedal.
This link has some great illustrations of the booster in different operating positions,which details its function clearly.
http://www.agcoauto.com/content/news/p2_articleid/129
wbrockstar is offline
Old 07-29-2019, 12:05 PM
  #176
Brian Roe
Brian Roe's Avatar
My ignition coil was brand new with the new motor...
I want to make sure all those sensors are good before I take it to a shop. I just don't know how.
I had exact same problem and it was my maf sensor
Brian Roe is offline
Old 07-15-2022, 11:11 AM
  #177
Hanksta
Hanksta's Avatar
Originally Posted by mattdel
The description of your problem fits the symptoms of a common Fox body issue involving the baffle inside the fuel tank. It breaks loose over the years, then eventually just swims around the tank, lodging itself in various places, breaking the sending unit for the gauge, and sometimes lodging itself underneath the pump, causing a volume flow issue, which would in turn create your exact symptoms, to a T.
I'm sure other people are going to chime in with sensors to test, etc... After all that doesn't work, go ahead and drop the tank. Open up the fuel pump side of it(the right side) and look down. When you don't see the baffle neatly welded to the tank, encompassing the pump nice and cleanly, go ahead and replace the tank. Problem solved.
This isn't exactly true because my 95 mustang is doing the exact same thing and I just dropped my tank and even replaced my fuel pump and filter and my car is still doing the same thing I've replaced most of the sensors , the spark plugs , the wires, the brain and I'm still having the same problems I'll be driving and and all of a sudden the car will just dump the power I can keep going and sometimes it will all of a sudden give me back full power only to loose it again a short distance down the road sometimes I won't loose it at all and can drive for several miles before I lose power but most of the time I just pull over shut the car off real quick and restart it and have full power again only to loose it again a block down the road so if someone has any ideas please help please.
Hanksta is offline
TexasSoldier713
06-18-2012 10:27 PM
Frantz
02-09-2012 04:58 PM
Batenswytch
09-23-2009 05:56 PM
xB1u3xF1v3xO
05-02-2008 08:05 PM
xB1u3xF1v3xO
04-14-2008 06:13 PM
Quick Reply: Power loss, hesitatation, sputter, chug
