waterpump change?
Old 08-17-2009, 10:12 AM
Tony71502
Tony71502's Avatar
Originally Posted by 68CSTANG
Because the belt is wrapping around the WP pulley different than stock, causing it to spin the other way. The belt is now going over the top of the WP from the alternator. Like these: http://forums.corral.net/forums/show...rnator+bracket
Unless your alternator and power steering pump are both on the same side of the block, your pump is going the right way, regardless of your belt routing.
The only way your pump will spin reverse is if the belt does NOT cross from one side of the water pump pulley to the opposite side of the crank pulley.
Check out my horrible drawing for what I am referring to.
Tony71502 is offline
Old 08-17-2009, 11:05 AM
68CSTANG
68CSTANG's Avatar
The OP isnt using PS so the belt doesnt go to both sides of the crank pulley. It should just make somewhat of a triangle around the crank, alt, and WP. So everyone is correct
68CSTANG is offline
GimpyHSHS
19
12-19-2023 01:12 PM
flash_xx
10-16-2015 07:23 AM
Dathan
10-05-2015 05:52 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: waterpump change?
