91 LX 5.0 T5 Issues
Old 09-09-2009, 06:54 AM
Martin5.0
Martin5.0's Avatar
Default 91 LX 5.0 T5 Issues
i have a 5.0 LX and it has a T5. I have a issue with it not shifting into forward gears. It does have reverse. It has a Pro 5.0 shifter and someone has told me that it maybe a shifter issue. It started by looseing 1st then 3rd then 5th then 2nd and finally 4th leaving reverse alone. What could be going on here. I am researching this for my Brother cause he is home trying to fix this while im in Iraq. Please advise on what to look for or even maybe a good transmission to replace it with. i have 1500 to spend on the trans.
Martin5.0 is offline
Old 09-09-2009, 09:32 AM
Tony71502
Tony71502's Avatar
It HAD all the gears at one with and now you can't get into any?
Tony71502 is offline
Old 09-09-2009, 11:54 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
first check the cable and make sure it is adjusted properly/ moving the fork arm down on the tranny.
mjr46 is offline
Old 09-09-2009, 08:35 PM
Martin5.0
Martin5.0's Avatar
It started with looseing 1st gear then over the next couple weeks i started to loose the other forward gears. I still have reverse. The shifter lever wont move into any forward gear at all. I cant even force it into gear.
Old 09-09-2009, 08:51 PM
AdderMk2
Banned
AdderMk2's Avatar
just stop now before you seriously FUBAR the trans....
take it out and replace it. T5's are cheap
AdderMk2 is offline
drfister
05-03-2018 10:38 PM
Meystang
09-25-2015 04:05 PM
YoungStangsMan
09-05-2015 07:01 PM
1st 4 eyed fox
08-24-2015 06:56 PM
Quick Reply: 91 LX 5.0 T5 Issues
