Coolant loss need help
Old 10-18-2009, 05:46 PM
five-0
five-0's Avatar
Default Coolant loss need help
I've been losing coolant in my 89 5.0 so i thought i had a bad head gasket the only problem is that the motor shows no signs of it. The oil is clean, no smoke from exhaust and it doesn't smell sweet, all plugs look pretty clean and it hasn't overheated even when rock crawling (its in my jeep). Is their anything else i should look for or could the coolant be evaporating? (i have a 20 oz mountain dew bottle for an overflow)
five-0 is offline
Old 10-18-2009, 05:55 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Have you pressure tested the system? That would be a place to start.
PRO50SC is offline
Old 10-18-2009, 06:21 PM
five-0
five-0's Avatar
Not yet that will be tommorrow I was wondering if their was anything else that i could have overlooked.
five-0 is offline
Old 10-18-2009, 07:15 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Check the carpet, make sure the heater core isn't leaking.
PRO50SC is offline
Old 10-23-2009, 09:30 PM
five-0
five-0's Avatar
Is it possible that coolant is getting pushed out of the overflow bottle? I know hat my 4.0s dont push out a ton of coolant when running but I'm not sure about this motor with a stock wrangler radiator.
five-0 is offline
Old 10-23-2009, 09:40 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Its possile but that would be a sign of a bad radiator cap. If the system cant hold pressure it goes into the overflow and once it fills up it spews it. Once the system cools it sucks it back down and you have to keep adding coolant. Pressure test the cap and system.
Boss_Hotrod is offline
Old 10-23-2009, 09:49 PM
five-0
five-0's Avatar
The system passed the test. How do I test the cap?
five-0 is offline
Old 10-23-2009, 09:53 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Same way but w/ an adaptor for the cap.
PRO50SC is offline
Granatelli Sales
01-20-2020 12:34 AM
Nick Oliver
10-17-2018 04:22 AM
baddog671
07-26-2016 01:20 PM
wraith777
09-28-2015 10:49 AM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: Coolant loss need help
