Possible fuel pump issue
Today I went to start my 91 GT for the first time in about 3 or 4 months. I had to get another battery cause it was dead. Put the battery in and turn on the ignition and the fuel pump did not kick in.
Could it be a fuse?
Where's the fuse for the fuel pump located?
Is the fuel pump hard to change?
Could it be a fuse?
Since it looks as though I'll be changing my fuel pump, is there a recommended upgrade for this part? I saw 255LPH FUEL PUMP online. Is this a good one? What's the difference between this one and the stock pump?
stock is 88 lph.that is the first upgrade you do on a 5.0. i went 190 but 255 is the norm. i went with a walbro pump. and if you don't allready know when you do it just use the buttsplices that come with it and no you can't get a spark cause the air is to rich in the tank even on empty. you'll know what i'm sayin when you do it. buy a filter. and the pump and filter come with the white clips in the fuel fittings.hope that helped.
did you verify that was the problem or are you guessing???
TfcCDR
09-14-2015 12:08 PM
zanemoseley
09-06-2015 12:58 PM
