302 heads
Old 01-19-2010, 06:52 PM
generallee440
generallee440's Avatar
Default 302 heads
i am building a motor for my 91 and a got a set of 351c 4v heads i want to put on my 302 iknow you need a new set of header and i know the heads will fit on a 302. i want to keep runing efi on my car. does any one make a intake for something like this,iknow trick flow makes one for a windor if any one know any thing about please let me know
generallee440 is offline
Old 01-19-2010, 08:01 PM
AdderMk2
Banned
AdderMk2's Avatar
If you seriously are asking these questions... you really dont have what it takes to do a "Clevor" build. I would suggest you read up on it a bit.
FWIW, Ford Racing has an article about it in there parts catalog
AdderMk2 is offline
Old 01-19-2010, 08:12 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
google clevor.... to build it right, you[d be better off building up your current motor
mjr46 is offline
Old 01-19-2010, 08:29 PM
generallee440
i know you have to have the right pistons to have the right vavle clearance and have to mod the heads like block the coolant passage and remove the alignment pegs and have the right head gasket and need a special intake i know how to build the motor to make it work i have a cleaveland in my 70 mach. i just cant find a intake for the 302 with cleaveland heads that will work with efi that what i am looking for thanks
Old 01-19-2010, 09:01 PM
AdderMk2
Banned
AdderMk2's Avatar
check with edelbrock.. IIRC they make one
AdderMk2 is offline
Old 01-19-2010, 09:11 PM
67mustang302
67mustang302's Avatar
I think CHI may make one as well.
67mustang302 is offline
Old 01-19-2010, 09:31 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
can always use the Bush perfomance manifold and add injector bungs and use a elbow with the throttle on it etc...
rmodel65 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: 302 heads
