pistons
Old 01-25-2010, 02:17 AM
rex90lx
rex90lx's Avatar
Default pistons
can you run a .030 over chevy piston in a .030 302 block to get a higher compression engine
rex90lx is offline
Old 01-27-2010, 12:34 PM
jkrum10238
jkrum10238's Avatar
your gunna need to be more specific than that but ive heard of ppl using chevy pistons in strokers
jkrum10238 is offline
Old 01-27-2010, 12:37 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
it depends on the type of piston weather it be a flat top, dome, piston relief size, positive or negative cc's. only way to tell is look at the box they come in or a spec sheet as far as the specific info needed to figure out if you wil have higher compression or not.
FivePointOhh is offline
Old 01-27-2010, 10:17 PM
tinman
tinman's Avatar
You would need to re-balance everything anyway......
tinman is offline
Old 01-28-2010, 12:06 AM
rex90lx
rex90lx's Avatar
i am wanting to build 331 but use domed chevy pistons to get the higher compression say around 11-11.5-1 just on the verge of not being able to run 93 oct
rex90lx is offline
Old 01-28-2010, 08:51 AM
AdderMk2
Banned
AdderMk2's Avatar
my 347 uses ford 331 pistons. and I make 11.25:1 comp...
dont cross breed, just get the right stuff
AdderMk2 is offline
Old 01-28-2010, 10:19 PM
rex90lx
rex90lx's Avatar
thanks adder i will just curious on if would work
rex90lx is offline
Old 01-29-2010, 06:47 AM
uedlose
uedlose's Avatar
the pin is a different size the valve placement is probably different and you will need to look at Compression Height. While it has been done. Why would you when there are off the shelf pistons that will work
uedlose is offline
Old 01-29-2010, 06:35 PM
Bubba 95SN
Bubba 95SN's Avatar
Henry is rolling in his grave. Chevy inside a Ford blasphmey I say.
Bubba 95SN is offline
Old 01-29-2010, 09:19 PM
rex90lx
rex90lx's Avatar
it was just a hypothetical question i am in process of building the 331 with diamond pistons
rex90lx is offline
uberstang1
12-07-2017 07:10 AM
poke68
12-15-2015 06:25 PM
uberstang1
09-20-2015 06:42 PM
degner122
09-16-2015 07:09 AM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: pistons
