Typhoon Intake vs Gt40
Old 07-24-2005, 08:13 PM
NightmareStang22
NightmareStang22's Avatar
Default Typhoon Intake vs Gt40
I own a stock 94' 5.0 HO and I have the motor torn down. I was going to buy a new upper and lower intake, as well as headers. Now I must choose between two. Either the Typhoon kit EFI, or go with GT40 Intake kit. I would like to know which is best, and about how much HorsePower they would give me. Thanks in advance.
NightmareStang22 is offline
Old 07-25-2005, 02:33 AM
NightmareStang22
Default RE: Typhoon Intake vs Gt40
Will somebody please help me out, I have to make the decision quickly.
Old 07-25-2005, 02:35 AM
Stinger
Stinger's Avatar
Well if you staying stock use the GT40.. If you gonna make some changes like heads etc go with typhoon. Its very close to a Performer RPM just a cheaper casting. I use the Typhoon intake and it makes a good cheap intake and does the job very well but i had heads , cam, etc. Good luck in your choice.
Stinger is offline
Old 07-25-2005, 01:36 PM
stanglx2002
stanglx2002's Avatar
yeah the typhoon is a good intake but you should polish the ports when you get them bc of the cheaper casting to make everything smooth if you dont want to hassle with the work then buy a edelbrock and be done with it
stanglx2002 is offline
Old 07-25-2005, 03:19 PM
vfast
I ♥ Acer
vfast's Avatar
first why not buy a used intake to save $$$$$ I used the gt40 on most my car but even used now thier over 400 as the look awsum and performe well...what are you run and what's in the engine before I would even make a suggestion..remember it's a package deal that works best
vfast is offline
Old 07-25-2005, 04:29 PM
NightmareStang22
Well I just got the head back today And plan on putting it all back together tomorrow and see how the motor does stock. If it does fine I plan on going with this setup. Typhoon upper and lower intake, X 303 cam or E303, BBK shorty headers, Ctaback exhaust with H pipe and 1.7 rockers. I may switch heads, but not sure what to get. Any advise on this setup?
Old 07-25-2005, 05:06 PM
Albizo66
Albizo66's Avatar
Nicee..I got the X303..just put it in..just make sure you know what you're getting with it..this thing is i-n-t-e-n-s-e man..and I mean intense..I know you said shorties..but I was told that Longtubes are best for this cam..but you should be OK
Albizo66 is offline
Old 07-25-2005, 05:11 PM
NightmareStang22
I can go with Longtubes, I just thought about shorties because they bolt right up and theres no cutting required. I just had to Take the stock headers off of a 75' Camaro and put Long tubes on them. Pain in the *** with a damn hand saw, had to cut through two pipes on one of them.
Old 07-25-2005, 06:54 PM
99saleen351r
99saleen351r's Avatar
You dont have to cut anything with a hacksaw!LOL but you will need a new H-pipe or X whatever you use
99saleen351r is offline
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
Dokilar
15
10-16-2015 08:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
69Volunteer
09-30-2015 10:39 AM
Quick Reply: Typhoon Intake vs Gt40
