anyone know where to get this/ what is it
Old 03-03-2010, 09:08 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
I've sheared off a few 3/8 drive heads before lol. I bent the hell out of a 5/16 wrench at work one day putting in a right angle drive on a Bradley.......anyway PB Blaster, heat, and an impact will rip those bolts right out OP.
projectresto83 is offline
Old 03-03-2010, 04:26 PM
im_stuck_in_iraq
im_stuck_in_iraq's Avatar
he is just that strong and can bend tools at will
im_stuck_in_iraq is offline
im_stuck_in_iraq
I used to drive a bradley
Old 03-04-2010, 08:46 AM
usc49erfan
usc49erfan's Avatar
well problem solved, ordered a new aluminum driveshaft
usc49erfan is offline
Old 03-04-2010, 06:11 PM
ikeybmg
ikeybmg's Avatar
I broke a 3/4 adapter on a 1/2 wrench with a 1 11/16th socket changing a u-joint in the front wheel of my dodge the other day. Had a 5ft pipe on it. I done it putting it back on so I figured it was tight enough.
I agree, using heat will help break it loose. It's a proven fact jack! And never use a 6 point on 12 point bolts just in case you did'nt know. You need an impact.
ikeybmg is offline
Old 03-04-2010, 07:36 PM
usc49erfan
usc49erfan's Avatar
yea i tried everything but the impact, the way i viewed with the amount of money a decent impact would have cost i could just buy a new driveshaft, which is what i ended up doing
Old 03-04-2010, 11:58 PM
ikeybmg
ikeybmg's Avatar
That prolly was the best thing to do. I had a stock d/s I could have sent you for like 20 bux.
ikeybmg is offline
Old 03-05-2010, 07:41 AM
85-foxmustang
85-foxmustang's Avatar
I know that this sounds stupid but last time I had to do take out them bolts I used a snap-on ratchet and a bottle jack under it and jacket it up pb blaster the crap out of the bolts try and heat up the yoke and one of three things will happen you brake the bolt, brake the ratchet, or it comes out. i got lucky and the came out. the last guy that had the car put lock tight everywhere on the bolts
85-foxmustang is offline
Loganisapro
07-14-2012 11:52 PM
9550
03-28-2012 06:34 PM
05pnygt
04-24-2010 10:39 PM
eventer289
11-09-2009 11:00 AM
djcondo
11-18-2008 09:58 PM
Quick Reply: anyone know where to get this/ what is it
