Some sort of whistle ??
Old 07-27-2010, 09:22 PM
captahab
captahab's Avatar
Default Some sort of whistle ??
I just installed a BBK Cold Air Intake (fender kit) . The previous intake was a March Ram Air that a previous owner had installed. The March kit was below the bumper and was all busted up when I purchased the car so, I decided to change it out.
Anyway, now that the BBK is installed I seem to get a faint whistle coming from inside the engine compartment when Im on the throttle. Its not constant but comes and goes under throttle. I checked all the clamps for the intake and everything seems tight. Im thinking its sucking air somehow but I cant seem to locate where. Could it be the air is somehow making a noise as its bieng sucked through the inside of the fender? The car runs good, idles good. I ran out of daylight today and will start over tomorrow. Does anyone have any suggestions ???????
Thanks.
captahab is offline
Old 07-27-2010, 10:00 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
THE WHISLTE is common , if you have a throttle body also that is aftermarket you'll need to plearance/port match the intake opening/ smooth any rough edges so that the air transition between the two points is smooth, otherwise the air will whistlr past the rough areas
mjr46 is offline
Old 07-27-2010, 11:02 PM
captahab
captahab's Avatar
Thanks for the reply on this. I was concerned I had something hooked up wrong.
captahab is offline
drfister
05-03-2018 10:38 PM
stark777
09-21-2015 12:46 PM
SteelerNation82
09-09-2015 09:06 AM
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
Quick Reply: Some sort of whistle ??
